egr or head gaskets? - Ford Truck Enthusiasts Forums
Old 09-12-2012, 01:09 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
As some of you know, I'm on the verge of a tear down on my 06 6.0. I want to do some digging to see the actual problem before I do. Symptoms I had was while towing a trailer. Truck over boosted to 40 psi, all stock, for about 20 seconds. Then came white smoke from the stacks and puking out the degas bottle. Truck idles great and has great power and no more smoke or puking. I replaced the cap with a new stant one to see if that was my problem.
With that being said, I know the turbo needs pulled and gone through. What other tests can I do to see whether it is the HGS or egr cooler causing my problems?
Old 09-12-2012, 01:30 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Hook a gauge to the radiator line into degas bottle and check the pressure while running. It should stay around ~10psi normally, but shouldn't go over 16psi.
There's a vacuum test for the EGR cooler while installed in this TSB:
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Puked Coolant Kdawg89 6.0L Power Stroke Diesel 60 01-27-2017 07:53 PM
Another blown head gasket, or is it? BryanStein 6.0L Power Stroke Diesel 32 09-25-2013 06:57 PM
coolant puking biggercb 1997 - 2003 F150 3 11-19-2012 10:36 AM
Blown head gasket symptoms. brickie 6.0L Power Stroke Diesel 16 07-29-2012 07:43 AM
Smoke and Scangauge EGV 0 and EGR 0 grahamdelooze 6.0L Power Stroke Diesel 11 05-12-2012 06:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
