Ecoboost crate engine - Ford Truck Enthusiasts Forums
Old 09-12-2012, 07:39 AM
ArtsBest ArtsBest is offline
ArtsBest is starting off with a positive reputation.
Can one buy the Ecoboost engine in a crate engine form? Or does Ford have the sole control over this engine? Just wondering for this would be a great engine to install in older vehicles seeing how it combines power with fuel efficiencies.
Old 09-12-2012, 09:44 AM
BigDfromTN's Avatar
BigDfromTN BigDfromTN is offline
BigDfromTN is gaining momentum as a positive member of FTE.BigDfromTN is gaining momentum as a positive member of FTE.
Quote:
Not sure,
BUT a call to your local Ford Dealer would surely give you a correct answer.
Old 09-12-2012, 10:35 AM
oldrifleman oldrifleman is offline
oldrifleman is starting off with a positive reputation.
I know they have spare engines listed in the parts catalog but I suspect that these would still need the complex computer control systems to control them.
Old 09-12-2012, 10:39 AM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.
with all the electronic these newer trucks have I think it would be a royal PITA to make everything work, and it probably wouldn't be cheap.
Old 09-12-2012, 01:38 PM
96sherm's Avatar
96sherm 96sherm is offline
96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.96sherm has a spectacular reputation.
Ahh...a question I've been wondering myself. I've been thinking about how much fun it would be to have a 3.5L Ecoboost in a lightweight Mustang. I'm sure you can buy the Ecoboost in crate format, but as has been mentioned, the expense and complexity of such a swap would be a hinderance.
Old 09-12-2012, 03:05 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
may be cheaper and easier to wait till the f150s start getting rear ended and rolled. then you can get everything. i think someone is doing this with a '66?
may i ask what is the engine destined for?
96sherm - i was waiting for the 2015 mustang ecoboost but it seems they are using the 2.0? from the focus. kinda sad but they have good reasons.
Old 09-12-2012, 03:26 PM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Quote:
Yes, indeed someone in this forum is putting an ecoboost into a 1961-1966 F Series. His name is Boss9F100. He bought a wrecked ecoboost F150 & started that project a few months ago & he is having problems with all of the wiring because he has no "hot rod" wiring harness. I recommend looking at it when you have the time. Link: http://www.ford-trucks.com/forums/11...eco-slick.html
Last edited by KingBigJoe; 09-12-2012 at 03:30 PM. Reason: I deleted a sentence & added the link in its place.
Old 09-12-2012, 05:11 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
As I understand his project, he's dropping the '66 body on the ecoboost truck frame and fabricating the dash and other parts to fit the new body.
Someone correct me if I'm wrong or misunderstood his post.
Old 09-12-2012, 06:20 PM
KingBigJoe's Avatar
I don't think you did. I slightly miswrote my post. My memory of his build is a little rusty unless I reread it. But, yeah either way it will be awesome if this gets finished.
Old 09-14-2012, 07:08 AM
96sherm... Mustang is one of 3 new models to be introduced to Ford's mix in Europe. Do not know what engines are available though. The Ecoboost is not available in the Mustang here is it?
Old 09-14-2012, 08:16 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
A eboost will be available in the 2015 mustang. I dont think they have said which level yet though.
Old 09-14-2012, 05:54 PM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
Yes, Ford Racing is going to offer Ecoboost crate engines in both 2.0L and 3.5L versions. Ford will announce availability dates and pricing at end of 2012. It will come with wiring harness and accessory drive.
Old 09-14-2012, 06:57 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Quote:
Imagine putting that motor into a small vehicle! That would be the ultimate sleeper!
Old 09-14-2012, 07:05 PM
QwkTrip's Avatar
... until it gets blown away by a turbocharged LS3 sleeper.
Old 09-14-2012, 07:17 PM
The sound difference alone would be on the Ecoboost side...you pull up in a vehicle with a LS3 and they are going to know something is up!
Where are all the Ecoboost conversions? FordBlueHeart 1999 to 2016 Super Duty 40 03-08-2017 01:19 PM
Am I the only one salivating over 2017 Raptor Engine? Dr G 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 07-10-2016 04:18 PM
2.0l Ecoboost Swap? mefast EcoBoost (all engine sizes) 11 05-07-2016 07:05 AM
Engine Replacement Richbal 1987 - 1996 F150 & Larger F-Series Trucks 14 04-17-2015 06:33 PM
Crate Engines bsteele52 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-29-2008 10:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
