dana 44 front axles f150 f250 - Ford Truck Enthusiasts Forums
Old 09-11-2012, 06:29 PM
JP808 JP808 is offline
JP808 is starting off with a positive reputation.
i have front axles from a 77 dana 44 f150 and want to replace the ones on a 77 1/2 f250 dana 44. are they compatible? thanks Jim
Old 09-11-2012, 07:26 PM
79silverstreak 79silverstreak is offline
79silverstreak is starting off with a positive reputation.
The 3/4 ton axle is 8 lug and leaf sprung, were as the 1/2 ton is 5 lug and coil sprung. The axle under the 250 is a hd44, and swapping it out to a standard 44 is a down grad, the differences are thicker tube, bigger hubs and bearings, dual piston calipers, possibly other things I can't think of. I am not exactly sure but the 150 44 may be standard low pinion, vs the reverse cut hd. Aslo wms to wms on the half ton is around 65" vs 69" on the hd.
What exactly is wrong with the current axle? If damage is too much to be worth it a 77.5-79 hd44 can be had for around 400 bucks depending where about you live.
Old 09-11-2012, 07:37 PM
just the the left and right inner axles with the u joints. visually they look the same . my f250 has wasted stubs and the f150 has new u joints sorry for the confusion
Old 09-11-2012, 07:46 PM
There is a difference between the stub shafts, not exactly sure, but I believe the spline count is different. I don't think they are the same length either. I should have known you were just asking about the shafts as to the (s) to axles.
Old 09-11-2012, 08:15 PM
thanks 79silverstreak , was hoping for the part I had worked. glad that you answered before I went to take them from the f150. Best of luck with your truck
Old 09-11-2012, 09:05 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
Yes, I agree with the above, the inner shafts should be the same but the outer stub axles are different.
Old 09-12-2012, 07:21 AM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
you may want to check that...my 78 f150 s/c had a leaf spring suspension and the inner axles were/are different than the coil spring d44, the coil spring inner axle leaked around the seal because it was slightly smaller, best way is to pull them both and mic them...
Old 09-12-2012, 08:10 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Actually, the 77 F150 axle had thick tubes, so there is no strength sacrifice there. Additionally, when I swapped 8 lugs on my axle, I used the F150 stub shaft. It was about 1/8" to1/4" too short, but it worked fine. The only thing was that when you were installing the snap ring, I had to push the axle out by reaching in to the u-joint.
In this article, he covers tube thicknesses:
Dana 44 Solid Front Axle: Part 1 Reverse Spiral Housing
Old 09-12-2012, 04:33 PM
Quote:
Yep, the F150 super cabs were oddballs... take different outers. Not sure if they are the same as F250 but just as a guess I think they might be.
Old 09-12-2012, 09:32 PM
thanks everyone, Teds74 article was good, at least we know that the u-joints are the same. I will check the axles side by side and see what happens but not this week and reply back
77.5-79 Dana 44 f250 front sway bar and links crazed87bronco Ford Truck Parts for Sale 1 11-28-2015 08:21 PM
AXLE SWAP QUESTIONS fordsford11 Washington Chapter 6 01-22-2012 12:41 AM
Dana 60HD rear and Dana 44 front fluid capacity kilich 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-01-2011 08:11 PM
Dana 44 front end parts amcv8jeep Clutch, Transmission, Differential, Axle & Transfer Case 2 10-05-2007 07:09 AM
pre 77.5 F250/350 Dana 44HD Dana 60 Raptor Offroad & 4x4 7 05-25-2006 05:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
