4X4 engages over 60km/hr
2007 F350, bad vibration around 70-80km/hr, it is like 4X4 is engaged. removed both lock hubs and marked both axle shafts and front drive shaft with paint marker. Drove truck and kept checking if marks moved, all good up to 60km/hr, but at 80 vibrating, marks on shafts moved. As if I was in 4X4, turn selector switch alot of times, still does it. With both hubs removed and in 2wh drive the shafts should not move. The T/C motor clicks when I engage 4wh drive every time. Any ideas. Thanks.
how much did they move?
an honest guess here but I was thinking its possible with the normal vibration and road conditions they would just "naturally" move slightly, and with the vibration issues causing the "natural" movement to increase. I'll check this on my truck, Ill be on a pretty bumpy highway tomorrow for about 100+ miles. Ill report on it tomorrow.
Superduty ROCKS
02-27-2014 02:38 PM
1987_XLT_Lariat_F250
01-06-2014 10:55 AM
