Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-11-2012, 01:43 PM
evilwunn evilwunn is offline
Garage is empty, add now
evilwunn is starting off with a positive reputation.
Traction control / Tire size
Once in a while when I take a corner my traction control activates and the light will come on. The tires aren't slipping, and it usually happens the first time I drive it for the day, then it won't happen again for weeks. The dealer checked it out this morning and said that because I have 275/65/18's on it instead of the 255/70/18's it came with, the traction control is getting a false signal and activating. He said that they tried to adjust the tire size with their computer but couldn't go to the size I have. He suggested that maybe adjusting the air pressure down a little in the tires might help.
Does anyone know if someone makes a programmer that will allow me to adjust for the tires I have? Has anyone else had this problem?
Thanks for any help.
  #2 (permalink)
Old 09-11-2012, 03:50 PM
RI-Matt's Avatar
RI-Matt RI-Matt is online now
RI-Matt is starting off with a positive reputation.
I believe both the Hypertech and Superchips programmers have adjustments to allow for different tire sizes.
Matt
  #3 (permalink)
Old 09-12-2012, 06:47 AM
Quote:
Matt
I checked those out online, it says it will recalibrate the speedometer and odometer for the tire size. Do you think doing that might help with the traction control?
  #4 (permalink)
Old 09-12-2012, 07:13 PM
RI-Matt's Avatar
I would think so. Ford probably has the traction control all figured out based on the stock diameter tire and any deviation from that may mess up the calculations.
Just think if you get the programmer not only can you adjust for the tires but you can pull a few more HP out of it. Win win.
Matt
  #5 (permalink)
Old 09-17-2012, 04:04 PM
johnkn johnkn is offline
johnkn is starting off with a positive reputation.
I'd take it to another dealer. There are always varations between manufactures even on the same tire size. BTW, TireRack.com shows Michelin 255x70x18 and 275x65x18 having the exact same 32.1" diameter. Sounds like they had no clue what the real issue is and tried to blame in on the tires.
  #6 (permalink)
Old 09-18-2012, 12:43 PM
Quote:
I saw that same thing online, the only difference is with the width of the tire, and the sidewalls are stiffer than the stock tires. I have been to two dealerships already and I am getting the same answer. I did drop the pressure down a few lbs. and so far no issues with the traction control activating. (knock on wood) I guess I'm just going to have to see what happens.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
