2010 Rear Sliding Window Defrost Issue.. - Ford Truck Enthusiasts Forums
Old 09-11-2012, 12:56 PM
Wikajomi's Avatar
Wikajomi Wikajomi is offline
Wikajomi is starting off with a positive reputation.
Oh Great F150 Gurus....PLEASE help this Old Phart....I have a 2010 F150 Supercrew XLT. I have ran the complete gamut as to this issue and am ready to give up--yet I know that the knowledge base of this forum should be able to solve this!
The rear defroster and heated mirrors are not working. I have checked fuses, connections, relays, and switches.....and still nothing. After reading a couple thousand threads all over the net, it is my understanding that if the rear sliding window is not completely closed they will not work. Apparantly there is a contact point or points that when the window is closed completes the circuit. I am quite sure that this is the issue with my truck. I cannot figure out where these contact points are. Or if a simple adjustment to the slider will resolve this.
Could one of you fine members steer me to where to look for these contact points? might it be a matter of simply brushing/cleaning these contacts? Is there a way to adjust the slider portion to align these contact points?
I am losing my mind in regards to this.....PLEASE HELP!!!!
PS Yes I have tried holding the defrost button while operating the slider to a closed position and yet still have no defrost operation.
Rear defrost issue nnero 2009 - 2014 F150 5 11-17-2014 12:10 PM
2012 F150 Rear Defrost Electrical Circuit? F250GH 2009 - 2014 F150 4 11-07-2014 01:42 PM
Power sliding rear window stuck open frisbeeguy 2009 - 2014 F150 15 09-30-2011 10:50 AM
Fixed rear window seal compatible with slider? flat4vw 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2010 07:45 AM
Power sliding rear window kfactor 2004 - 2008 F150 35 04-29-2004 04:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
