Valve train noise change at 60K
noticed more noise suddenly at 63000 miles. used to be quiet all the time even at start up. now it clatters like loose rockers or lifters. the only change was adding Lucas to the last oil change. I have changed the oil and it seems to have quieted down some. has anyone had trouble with using heavier oil than recommended? I have never run the 5-20 in it. always 10-30.
Hi Guy,
Well like you have probably decided as well, Lusac is not something I would use in an engine....there is probably some residual in there right now and with your next oil change it should come out. I'm assuming you have a modular engine, regarding the use of heavier oil, well, I would not recommend that either as the hydraulic tensionors, etc really need the thinner oil to function properly & the 0-20 oil actually has the same viscosity properties as 5-30w of years past. Perhaps do another oil change to get rid of any possible residual, new filter as well and I would recommend adding 1/3 bottle of ZDDP (9 oz iirr) which should help on numerous fronts without creating any issue for the cats.
i worked at an oil change place and Lucas is the number one additive used. I have seen trucks with 400K with lucas used. I suspected the stuff is a little thick for the newer vehicles. I may have proved that. Thanks for the tip. I am trying to find what ZDDP is now. Bob
Yeah, lube oil change places use a lot of products that, well, don't really serve the best purpose...more of marketing than anything else. Not to re-direct the thread, but there is a tune-up chain that promotes fuel injection service/cleaning as part of routine maintenance. Now i am not going to say that this is a procedure for which there is no need, but, the fuel injectors that have been mfg for the last 10 years (approx), every mfg has a written directive not to perform injector cleaning as part of the maintenance 9or even repair) procedure because of potential damage to the injector and the unnecessary cost. Recently (last year) Jiffy Lube (corporate owned & operated stores in the Los Angeles area) were nailed for the second time by both news agencies and bureau of automotive repairs for fraudulently (in writing) advising people to perform services on both american & imports that the mfg's stated in writing "do not perform"....the local shop mgrs & techs were just following what the computer told them to do...so to speak.
Fixed part of it!!!
Changed the idler pulley on passenger side. It was wobbling. Got rid of the knocking sound. Still have what sounds like loose lifters. I am going to go back to 5w20 next change and see if that helps. There are two idlers so I changed the other one also. The bearing was tight on that one also.
If you have been using 10W-30 for the life of the motor & not the 5w-20 which is recommeded, the damage is probably already done! Good luck....
FlatRateTech | Automotive Technicians and Mechanics Community
