Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 09-10-2012, 08:27 PM
sgtcoyote sgtcoyote is offline
Garage is empty, add now
sgtcoyote is starting off with a positive reputation.
new 62 f100
I just bought a 62 F100 to days ago. It needs some work (RF drum locks up when brake depressed, dash needs to be put together, brake lights need to be replaced)
The brakes are in bad need of new shoes and I'm hoping thats why it locks up.
I want to replace the wire harness, still looking for a vendor
Any ideas or suggestions are welcome
thank you
  #2 (permalink)
Old 10-07-2012, 08:03 PM
Cazman1955 Cazman1955 is offline
1962 Ford F-100
Cazman1955 is starting off with a positive reputation.
catalogs
Get yourself a collection of part Catalogs such as:
Dennis Carpenter Ford Restoration Parts
Mac's antique Auto parts
National Parts Depot
LMC Truck
All these guys and more are on the internet and more than happy to send you a catalog. Also if you give them your email address they usually run monthly specials on parts or accessories. Shop and compare prices, and have fun restoring your pride and joy!
  #3 (permalink)
Old 10-11-2012, 02:57 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a good reputation on FTE.Customcab has a good reputation on FTE.
Welcome aboard;
Ricks Carolina Classic NC; and the Truck & Car shop in Cal are also great vendors for parts.
I just purchase a 62 lwb big window yesterday myself; once I finish several other projects; I plan on doing a frame off resto & will replace the 292 y block with a 262 six banger!
__________________
Mitch
63 F100 LWB 302/AOD (Orphan box) Daily Driver.
62 F100 LWB 292/3spd (Uni-body Big Window)
57 F100 SWB 351C/FMX; (Big Window)
93 F150 4x4 Regular Cab Daughters 2nd truck
62 Flairside SWB "Wife truck"
  #4 (permalink)
Old 10-12-2012, 09:09 AM
cobraguy cobraguy is offline
cobraguy is starting off with a positive reputation.
You'll probably find the cause of the wheel lockup is a frozen wheel cylinder on the opposite side. If the truck has been sitting for a long time consider doing all the brake hydraulics along with shoes and hardware. I'm not sure on a direct replacement wire harness but there are some good aftermarket universal ones out there. I've used Painless on another project and was happywith it. Oh I almost forgot....Welcome to FTE
__________________
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
11 Kia Forte 5
3 Bikes
  #5 (permalink)
Old 10-14-2012, 10:49 AM
pburress's Avatar
pburress pburress is offline
1963 Ford F-100
pburress is starting off with a positive reputation.
In my '63, the brakes worked but not very well. I found that the wheel cylinders were all full of dirt and crud. I'd recommend you go ahead and replace all the wheel cylinders- they are only $10-$15 each. If you have the single-piston front wheel cylinders, you can upgrade these to dual-piston.
  #6 (permalink)
Old 10-14-2012, 08:26 PM
Customcab's Avatar
If you have the single-piston front wheel cylinders, you can upgrade these to dual-piston.[/quote]
I didn't know that; thanks for the info. Finding single piston thru local autoparts stores is like pulling hens teeth!
Thanks.
__________________
Mitch
  #7 (permalink)
Old 10-15-2012, 04:29 PM
pburress's Avatar
1963 Ford F-100
Customcab, On my '63 (NOT '64- sorry) I just bought the (dual piston) front cylinders for the '64 F100 and they bolted right up. I did have to get two additional pins, from National Parts Depot. They have them listed for '48-56 but they are the exact match. Here's the thread detailing my brake job: http://www.ford-trucks.com/forums/11...questions.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
