Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2010+ Ford SVT F150 Raptor
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2010+ Ford SVT F150 Raptor SPONSORED BY:
  #1 (permalink)
Old 09-10-2012, 05:48 PM
Truckmageddon Truckmageddon is offline
Garage is empty, add now
Truckmageddon is starting off with a positive reputation.
97 F150 Won't Fire
Can the GEM module cause no juice to the coil pack? I have checked every fuse and relay on the truck! PLUS changed the ECM (or main computer) at the RH kick panel. Any ideas or comments will be greatly appreciated.
  #2 (permalink)
Old 09-10-2012, 10:12 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Wrong section.
__________________
Speed is a question of money. How fast "CAN" you go?
  #3 (permalink)
Old 09-10-2012, 10:36 PM
Thanks
Yep I realized that as soon as I checked my post. My brain did punch on the 97 section but the hand and mouse missed it.
Great forum.
  #4 (permalink)
Old 09-14-2012, 08:42 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
2011 Ford F-150
Papa Tiger has a good reputation on FTE.Papa Tiger has a good reputation on FTE.
Do you have any codes? No power means power isn't getting from the ECU to the coil. Look for a broken wire/bad connector. Look for a bad wire at the ECU plug also. Test thru the circuit for the open spot. Your key turns on the relay. Swap out the relay with a good one. Relay turns on the ECU and so forth.
__________________
Women might not find ya handsome but they will find ya in your F150.
Ford Built_Ford Tough
  #5 (permalink)
Old 09-14-2012, 10:14 PM
Thanks PapaTiger,
The problem was a bad conn at the plug on firewall by the top RH side of engine. I went over and posted on the 97 up section and got a lot of advice. I had checked every fuse and relay multiple times and had it boiled down to the hot wire between the relay and coil pack. But didn't know it's route. Turns out you were right also! Lot of great folks on here. Thanks
  #6 (permalink)
Old 09-15-2012, 12:28 PM
Papa Tiger's Avatar
2011 Ford F-150
Those pesky connections!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
