Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- VIN Decoder
Important information to help you understand your Ford truck
11 digit Vin decode
#106
There is a lot of valuable info on this sight! I would like some help with my VIN as well.F60D8410929 WB 156, color G, Model 602, Body 81B, GVW 19,500, HP 153, RPM 3600, DSO 34
I believe it is a 63, I see it is a F600. Not sure if it's a 292 or a 330. I'm trying to find ignition timing specs, but not sure which engine I have.
Any and all help would be appreciated.
Thanks,
Hoke
Thanks,
Hoke
#107
The 5th digit of the VIN is a letter, not a number. You omitted the TRANS & AXLE codes.
F60 = F600.
D = 292 4V Heavy Duty.
8 = This should be a letter for the assembly plant.
410929 = 1963, assembled May 1963.
156" Wheelbase.
G = Chrome Yellow.
F602 = F600 .. 19,500 lbs. GVWR
81B Custom Cab.
TRANS code = Omitted.
AXLE code = Omitted.
19,500 lbs. Gross Vehicle Weight Rating.
153 net HP @ 3,600 RPM
34 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
#109
N75 = LN750 (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
C61829 = 1976.
184" Wheelbase.
T = Candyapple Red (there should only be one T).
LN752 = LN750 (gas), 23,000 lbs. GVWR
HC8: HC = Dark Tobacco Vinyl / 8 = Custom Cab w/o Butterfly Hood.
M = Clark model 285V 5 Speed Direct.
E2M:
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
M = This sorta looks like an M (but it might be something else) = Ford 7,000 Capacity Front Axle with Power Steering.
23,000 lbs. Gross Vehicle Weight Rating.
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
#114
R70 = LN700 Diesel.
O = Detroit model 6V-92TTA 552 cid 6 Cylinder Diesel.
DC6569 = 1979.
148" Wheelbase.
M = Wimbledon White.
R707 = LN700 Diesel .. 27,500 lbs. GVWR
8A8: 8A = Black Heavy Duty Vinyl-Full Width Seat / 8 = 81B Custom Cab w/o Butterfly Hood.
JC: J = CA emissions / C = Fuller model RT-610 10 Speed Direct.
AXLE code impossible to read, partially covered up by rivet.
27,500 lbs. Gross Vehicle Weight Rating.
711843:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
1843 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
DC6569 = 1979.
148" Wheelbase.
711843:
#115
Thanks!
Thank you!!!
R70 = LN700 Diesel.
DC6569 = 1979.
148" Wheelbase.
711843:
DC6569 = 1979.
148" Wheelbase.
711843:
#119
If you post a pic of the Warranty Plate (riveted to the left door face below the latch), I'll decode that too.
The TYPE/GVW aka MODEL code stamped on the Warranty Plate defines what the truck is.
