HPOP? - Ford Truck Enthusiasts Forums
HPOP?
Old 09-09-2012, 10:22 PM
blueline970 blueline970 is offline
blueline970 is starting off with a positive reputation.
HPOP?
Ok 2004 Early build. 2290 code give it skinny peddle ICP stays low around 700 to 800 and IPR goes up to 80%+. Let off and ICP shoots up over 1000 and IPR drops to 30%. Truck isn't making boost either only making at 15. My HPOP I know bleeds down when sitting over night I'm guessing it is time to replace?
Old 09-09-2012, 11:04 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Sounds like it to me, but hopefully others will jump in.
Old 09-10-2012, 05:48 AM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Have you had any no starts yet , hot or cold ?
Old 09-10-2012, 08:54 AM
Only when nose up on a hill and the truck has been sitting a while. Cheezit has said in previous thread pump bleeds down from seal going bad.
Old 09-10-2012, 12:06 PM
Well she died on me. Can only make about 380 on ICP and IPR is 83%.
Old 09-10-2012, 04:12 PM
Quote:
Yes he has, maybe pump problem .
Old 09-14-2012, 10:14 PM
Ok just quick update. Been on vacation so I haven't had a chance to see what would happen on cold start. Was parked nose down as always but took aroung 6 seconds of cracking to build any pressure. When it did fire up pressure was reading in the 800 and IPR was in the mid to upper 30s. Absolutely no power. Guess ill get to have some fun in my driveway pulling HPOP.
Old 09-15-2012, 10:08 PM
Should the pump leak back towards the suction side any? Took some shop air to my HPOP on the discharge side and can hear it leaking to the suction side.
Old 09-16-2012, 12:26 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
if leak is isolated to back of engine, it may be leak from HPOP. replace current stc fitting with updated stc fitting. from ur symptoms, sounds like it's pointing towards the HPOP.
Old 09-16-2012, 01:08 PM
Yeah I have early 04 no stc fitting. Really wish I had a top side creeper.
Old 09-16-2012, 01:55 PM
Snuggyworm's Avatar
thats right. my bad. i forgot to see the year of ur model. i dont suppose the early build 04 have the STC fitting, right? or does it? correct me if i'm wrong, guys. i'm sorry. i was in my own little world.
Old 09-16-2012, 01:57 PM
Snuggyworm's Avatar
it could be something really simple n straightforward like a worn-out o-ring seal.
Old 09-16-2012, 04:18 PM
I think I should have explained something a little better. I took the pump out and put air to it on outlet side and could hear it coming from inlet side.
Drain the HPOP to change IPR? bigcountry1009 1999 to 2016 Super Duty 0 12-25-2014 10:42 PM
ICP 97_Stroke 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-03-2013 08:31 AM
another 2003 7.3 no start DPressley 1999 - 2003 7.3L Power Stroke Diesel 13 12-15-2011 05:32 PM
Truck cranks but no start...have AE...help? ajorn 1999 - 2003 7.3L Power Stroke Diesel 16 07-08-2011 11:55 PM
at a loss here... need help guys Muktown 1999 - 2003 7.3L Power Stroke Diesel 13 05-30-2011 04:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
