Fitting size for Brake master cylinder ports?
All,
I am installing a 2005 F250 diesel Super Duty brake master cylinder into a 79 crew cab project truck. I need to order the correct fittings for the brake line output ports. They don't appear to be SAE.
Does anyone know the correct fitting size for the front and rear ports?
Thanks,
Checksix
Thanks,
Checksix
All,
Thanks,
Checksix
Thanks,
Checksix
You could take the MC to the parts store and check it with some of the pre-fabbed lines, with metric bubble flare fittings on them, to figure out which fitting size matches the ports.
Dirty Offio
10-18-2015 07:09 PM
Cougar54
09-29-2014 05:37 PM
ghunt
02-09-2009 12:19 PM
