Weird Electrical Problem - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-09-2012, 04:10 PM
JazzVT321 JazzVT321 is offline
JazzVT321 is starting off with a positive reputation.
I have a 2001 F25 with the 7.3L. Recently I've encountered some kind fo electrical problem. I think. When I bring my truck to a stop and put it in park the truck will rev the engine up to about 1300 or 1400 RPM for a few seconds then settle back down to idle. Also one time while stopped and in park the speedometer started jumping all over the place. I have a DP Tuner. The truck will do this when I have to tuner on and when I have the tuner off. I don't know where I need to start looking. Can someone point me in the right direction of where I need to look to fix this problem? I can answer any further question y'all might have. I recently replaced the speed sensor because it threw a code and was hoping that would fix the problem and it didn't. Thanks for your help.
Old 09-09-2012, 06:18 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
id pull the chip first, see if problem exist.
Old 09-09-2012, 06:59 PM
Okay. Thanks. I'll try that. Anybody else ever experienced this?
Old 09-09-2012, 07:00 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Check the alternator output for voltage and amperage.
Check the batteries for voltage and amperage.
Get a digital volt meter that plugs into the cigar lighter or power point.
12V/24V Car Digital Battery Volt Meter - USD $ 6.99
An improper voltage can cause some of your symptoms.
Old 04-06-2015, 08:58 AM
thomabb's Avatar
thomabb thomabb is online now
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Did you ever find the root cause of your problem? My truck did the same thing to me the other day.
Old 04-13-2015, 08:34 AM
thomabb's Avatar
I think my problem is linked somehow to the trailer brake controller. I leave my controller unplugged when not in use. I only have the symptoms when I plug my controller in, with or without a trailer. At this point it makes no sense to me.
2008 F350 6.4 Tuner 724x4 6.4L Power Stroke Diesel 18 06-11-2015 02:36 PM
6.0 TPP CEL and codes guydiver12 6.0L Power Stroke Diesel 0 11-02-2014 01:27 PM
F250 7.3 service engine light won't go away edge tuner Froger1997 1999 - 2003 7.3L Power Stroke Diesel 5 05-25-2014 11:25 PM
OBD2 Problems (tuner) Dutch13 1999 to 2016 Super Duty 4 02-22-2014 08:49 PM
Help request for a 7.3 no start Ogre39 1999 - 2003 7.3L Power Stroke Diesel 32 05-31-2013 07:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
