High Pressure Oil Pump leak questions - Ford Truck Enthusiasts Forums
Old 09-09-2012, 12:16 PM
samantha.hamrick's Avatar
samantha.hamrick samantha.hamrick is offline
samantha.hamrick is starting off with a positive reputation.
Ok this is going to be a long post. I own an 02 F350 Superduty 7.3L. I've been having an oil leak for some time now. Its hard to find the source with all the splatter under my truck. I'm told the most common problem is the HPOP and a mechanic told me it was the rear plug of the HPOP that was leaking and he couldn't get it off. Is this some sort of a lie because Ford says the same thing, but ive read on this site that it IS possible to remove with a ratchet . I'd like to start small and replace the plug & o ring first ( anybody have a part # for that?) and is it possible to visually check the seals and hoses for leaks as well without removing a bunch of other parts? I'm ready to get this thing fixed! I don't want all my oil to dump out on the freeway and leave me stranded somewhere. Thanks to any of you guys that can help me.
Old 09-09-2012, 02:35 PM
lostinafog's Avatar
lostinafog lostinafog is offline
lostinafog is starting off with a positive reputation.
first off need to clean up the engine to see the source then proceed
most common leaks are the HPOP & it`s hoses orings takes special orings & thread lock the plug will---- but not always strip the threads on removal not to be messed with till sure it is the source of leak!
also the dipstick mount on the oil pan behind the BIG nut if leaking can be loosened clean clean & clean again. behind it then finger push silicone between it & pan as you turn it in & tighten wipe off excess.
VC`s, front crank seal,rear main seal all possible but not real common.
but as first stated till engine is clean of excessive oil just chasing you tail
Old 09-09-2012, 05:36 PM
Can I spray engine degreaser underneath to get rid of the oil? It's covering the oil pan and other places as well.
Old 09-10-2012, 01:03 AM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
For cleaning, something like simple green would be a better choice. Also, start cleaning up top, near the HPOP and valley to confirm where your leak is.
Attached is a link for instructions for a HPOP repair kit sold by Diesel o rings. This may help you understand better. Bob is a good guy and a great resource for these trucks. You may get better responce if this thread was moved to the 7.3 section.
http://www.dieselorings.com/docs/fullHPOP.pdf
Old 09-10-2012, 06:14 AM
lostinafog's Avatar
simple green, super clean, purple power all good degreasers.
so you are saying the entire engine oil pan is covered in oil ? ifso not HPOP or lines as oil from them only will wet the engine valley & rear of pan & of course everything aft of that.
if you live or the truck came from area that used salt on the roads the oil pans are know to rust through.
so gota get er clean first.
Old 09-10-2012, 12:36 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
+1 one on inspecting the oil pan! Mine was recently replaced by the Previous owner. Around where I live I know of 2 trucks (02 F350) plow trucks that have gone through 2 oil pans in less than 4 years and less than 30,000 miles. The most common 7.3 leaks are up top that run down, the Low pressure oil pump or the oil pan. Good luck on the leak hunt!
Old 09-10-2012, 01:03 PM
There's a 7.3 forum? Good to know. I'm off to get sum simple green. I have to wash my truck anyway so mite as well get dirty under it too. I have a 6 inch lift with 38's so I can sit under my truck and spray. haha. Will be back when/if I discover the leak so I can ask any repair questions I mite have.
Thanks
Old 09-10-2012, 01:16 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Quote:
Sure is and I've moved your thread there for maximum exposure.
Old 09-10-2012, 01:24 PM
greenbeast7.3's Avatar
greenbeast7.3 greenbeast7.3 is offline
greenbeast7.3 is starting off with a positive reputation.
you can go to International dealer and get a rebuild kit for the hpop just did it. Dont goto ford to get it.
Old 09-10-2012, 02:51 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Thanks
The likely source of your leak will be on top of the engine. If you can get a good look at the valley between the cylinder heads you will see 3 basic retention areas (forward, center and rear). If there is oil in the forward area then you would suspect a leaking HPOP or fuel bowl seal (there are several...). A leak towards the rear area might be turbo pedestal or EBPV actuator.
As previously mentioned...the oil dipstick flange seal may be leaking also. If you find that is your problem then a reseal kit is available.
Oil Level Gauge Adapter Repair Kit for 1994 - 2003
Quote:
You can also get rebuild kits here:
1999-2003 Ford 7.3L
This past spring I decided to pull everything off and replace all the soft parts. No more leaks now.
I rebuilt the fuel bowl (replacing parker sleeves on fuel lines as well), replaced the HPOP o-rings (including the non-serviceable plug), replaced HPOP hoses and o-rings in the fittings, rebuild the EBPV, replaced the turbo pedestal o-rings and replaced the up-pipe donut gaskets. It took me the better part of a Saturday to get the work done.
Old 09-10-2012, 05:37 PM
Ok, I found a pool of oil almost directly under the fuel filter. Would that be the forward retention area you spoke of? Do I have to take out the fuel filter
assembly to get a good look at the pump and check the hoses and seals, plugs ??? UUUGG
Old 09-10-2012, 05:51 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
No, just look real close to the HPOP and see where its coming from. It could be the high pressure lines or the plug on the HPOP. Thats the most comom places and a cheap fix if you do it your self.
Chet
Old 09-10-2012, 08:14 PM
Lost.....Simple green worked like a champ! love that stuff.
Old 09-10-2012, 08:35 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
No, but you might as well plan on pulling the HPOP (just in front of the fuel bowl) so you can fix the leak at that rear plug that your mechanic nor the Ford dealer are competent enough to fix.
So far you're into this repair for a couple of dollars for the simple green. Spend another couple of dollars at High Pressure Oil Pump Repair Parts and you'll be back to a running truck with no oil leaks. The above link will come with instructions and pictures of how to change any parts you buy from him. We've been dealing with Bob for years and he's top notch and ships very quickly.
HPOP/Fuel Bowl R&R schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 11 12-21-2014 02:56 PM
Quick engine oil and HPOP oil question... Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 11 09-18-2014 11:40 PM
Oil Leak, suspect the Pan apeman426 1999 - 2003 7.3L Power Stroke Diesel 1 10-11-2012 01:46 PM
Turbo Pedestal Oil Leak Question disneyd 1999 - 2003 7.3L Power Stroke Diesel 1 04-14-2011 12:50 PM
HPOP Leak/empty & no start: twtcad 1999 - 2003 7.3L Power Stroke Diesel 76 03-23-2011 10:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
