7.3 powerstroke turbo torque specs
Old 09-10-2012, 05:13 PM
dmm50's Avatar
dmm50
dmm50 is offline
My rebuild kit for my turbo from Clay should be here tommorrow, I cant seem to find the torque specs for the Pedistal bolts/2 turbo bolts/all 5/16"12 point turbo housing bolts-steel housing and aluminum housing.If anybody has these I would greatly appreceate it.
Old 09-10-2012, 07:48 PM
F350-6's Avatar
F350-6
F350-6 is offline
The pedestal bolts are 18 ft lbs. Ford says the two turbo bolts are 18 ft lbs too. Garrett says the torque specs are 35 ft lbs.
18 seems to work fine on the pedestal, although I usually snug it a little past that. I've always used the garrett spec of 35 on the turbo and never had a problem with it.
Old 09-10-2012, 08:19 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Take a look at his OBS rebuild instructions. The torque specs are in there too. Bolts are pretty much the same for both.
http://www.riffraffdiesel.com/mm5/RE...bo_Rebuild.pdf
dieselbronc
03-04-2021 10:10 PM
endobear
04-24-2012 06:56 AM
midcal48
09-30-2011 11:18 AM
GOT 7.3 ?
07-02-2009 09:59 PM
yellow401
04-02-2006 08:20 PM
Quick Reply: 7.3 powerstroke turbo torque specs
