What oil is equal to Motorcraft - Ford Truck Enthusiasts Forums
Old 09-08-2012, 11:07 PM
sscarboro's Avatar
sscarboro sscarboro is offline
sscarboro is starting off with a positive reputation.
I've been having all my service done by a dealer using Motorcraft oil. I need to add oil in the morning and the dealer is closed till Monday. What commercially available engine oil is equivalent and compatible with the Motorcraft oil the dealer uses?
Thanks
Steve
Old 09-08-2012, 11:10 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
You can buy the Motorcraft oil from Wal-Mart. Otherwise I would use Rotella.
Piolet's Avatar
Piolet Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
If you really want to stick with the Motorcraft oil, you can get it off the shelf at Walmart. They sell Motorcraft brand oil and filters.
Old 09-09-2012, 08:17 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
As stated above however any diesel api rated CJ-4 oil will be good to go.
Old 09-09-2012, 08:37 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
When you switch brands of oil, you leave apprx. 3-4 quarts of the old oil in the system, so you are mixing oils at that point. Lots of people do it (switch oils that is)! As Mike said - any properly rated diesel oil will work.
Old 09-09-2012, 06:58 PM
miner999r's Avatar
miner999r miner999r is offline
miner999r is gaining momentum as a positive member of FTE.miner999r is gaining momentum as a positive member of FTE.
The mobile synthetic worked good for me - if you want to pay the extra dollars
Oil choices claycomotrucks1991 6.2L V8 6 08-14-2014 10:26 PM
Burnt macoroni Cold One 6.7L Power Stroke Diesel 16 03-04-2012 02:14 PM
HOW GOOD IS MOTORCRAFT OIL FOR MY 7.3 PAVEMENTMAN 1994.5 - 1997 7.3L Power Stroke Diesel 13 06-23-2010 04:35 PM
Normal Oil Consumption? live2hunt 1999 - 2003 7.3L Power Stroke Diesel 30 07-29-2005 08:34 PM
Oil for 5.4 Ltr V8 Pacovan 1997 - 2003 F150 15 02-29-2004 12:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
