Turn signal auto off... not... auto... offing... - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 09-08-2012, 08:37 PM
king-david king-david is offline
king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.king-david has a very good reputation on FTE.
In my slowly but surely progress with the Ex... I've run into another small issue. So yeah.. my Ex turn signal works fine.. just wont auto turn off. I dont know the tech term for whats happening or.... not happening. Anybody know the issue or the fix? I tried searching.. but I guess not knowing what it's called is hurting me
Old 09-09-2012, 12:21 AM
AndrewWV's Avatar
AndrewWV AndrewWV is offline
AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.AndrewWV has a very good reputation on FTE.
I have sort of the opposite problem. There are times I can't set the turn signal until I move the wheel one way or the other. Someone recommended changing the multifunction switch, but I haven't tried to yet.
Old 09-09-2012, 01:05 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Quote:
These are a pretty simple replacement job, it is funny how long
We deal with the inconvenience. The switch is around 115.00 or so
And it should take about a half hour to replace.
It is so much cooler than driving for miles down the road with your blinker
On.
Old 09-09-2012, 07:34 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
You may want to check online for that multi-function switch. I replaced mine 3 years ago for the same exact problem of not returning to the off position. It's one of the pins in the switch. I bought mine for about $65 from a parts dept. of a Ford dealership in Oregon, but online.
Old 09-09-2012, 09:03 PM
xbox73 xbox73 is offline
xbox73 is gaining momentum as a positive member of FTE.
Yep, I have the same problem. I was quoted a couple hundred bucks by the dealer to fix it (~$100 for the switch & ~$100 labor). I had just spent about $2k in maintenance after buying the X to get everything operational (A/C fixed, 3 out of 5 door lock poppers replaced, driver window switch & regulator, etc.), so it was kind of the last straw breaking point & I opted not to fix it at the time & maybe fix it at a later date. Honestly, I've got so used to canceling the turn signal lever manually that I automatically do it now without thinking. Since I've got so used to it, I'm not sure I'll ever fix it, unless I need to replace the MFS or do some maintenance in that same area for some other reason.
Old 01-06-2013, 07:56 PM
Bxrd Bxrd is offline
Bxrd is starting off with a positive reputation.
Post edited, became duplicate. How can I delete it?
Actually, I really have the exact opposite problem. I want it to STOP auto-off´ing. I hate how it switch off my pre signalling when entering a roundabout, or how it turns off the signal whenever I have to adjust adversely, ultimately affecting the curves I choose to make.
So basically, how can I disable the right connection? Preferably a mechanical fix, to also remedy the problem that certains positions of the driving wheel rotation keeps blocking the lever (probably tries to switch it off). Any help sincerely appreciated!
Cheers, Bård
Old 04-26-2013, 11:36 PM
Diesel Newb Diesel Newb is offline
Diesel Newb is starting off with a positive reputation.
OK, so it seems like the turn signal gets canceled WWWAAAYYY too easily in our X. Turn the wheel a couple of inches & off they go, turn it back on, clicks right back off. Would a new stalk would fix this?
Old 04-27-2013, 12:38 AM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Finally happy...
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Mine was doing this so I got a whole new column. On the way home from buying it it started working again Guess I'll toss the column in the garage until I need it lol.
Turn Signal Problem 1978f-250 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-21-2015 04:35 AM
weird turn signal/cruise/brake controller issue jayro88 1994.5 - 1997 7.3L Power Stroke Diesel 8 03-18-2014 09:20 PM
77 FORD F150 SMALL ELECTRICAL ISSUE TURBOSCHILZ 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-18-2014 11:48 AM
Steering/turn signal maverick600 Brakes, Steering, Suspension, Tires, & Wheels 2 02-01-2014 04:07 PM
turn signal blues Killgore 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-14-2014 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
