Transmission Problems on my 1988 F150 - Ford Truck Enthusiasts Forums
Old 09-08-2012, 06:28 PM
SomeoneTV SomeoneTV is offline
SomeoneTV is starting off with a positive reputation.
I have a 1988 F150 with an automatic transmission. Basically, whenever I try to accelerate from a full stop, the transmission does not want to engage first gear. Shifting to from first to second or higher goes smoothly. But, when the transmission tries to downshift back to first gear, the transmission takes a few seconds to engage. Interestingly, after driving it for a few miles and letting the transmission warm up, the transmission would shift to first gear normally. I want to know the possible causes for this and if there is a solution that does not involve getting my transmission replaced.
Old 09-08-2012, 07:56 PM
burnout400m burnout400m is offline
burnout400m is starting off with a positive reputation.
First off, what trans do you have? If you don't know look at the trans code on the door tag and find a decoder or post it up here.
Second, have you checked the trans fluid? There's a procedure to check it, you can't just check it like you'd do with the engine oil.
If you're still driving it to work and whatnot, stop until you get it figured out.
This is my 1,000th post on FTE. Hopefully is wasn't totally useless.
Old 09-09-2012, 12:33 AM
Thanks for the reply and on your 1000th post. My truck is a V8 5.0L (302) with a 4 speed automatic transmission. One thing I forgot to mention is that my truck got flooded once in the past year, and i had to get my gas tanks cleaned out and a fuel pump replaced. I will try to check the fluid tomorrow if I have time.
Old 09-13-2012, 12:25 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Water is an enemy to the MLPS and Solenoid Pack connectors. Both of which are critical to proper transmission operation.
Old 09-13-2012, 08:02 AM
Well you probably have the AOD trans. Is there a switch to turn off OD on the dash to the right of the steering column? The trans code from the door tag would be very helpful because there's a few possibilities.
Old 09-13-2012, 09:08 AM
rla2005's Avatar
Good catch there! For some reason I misread the OP's truck as a F250 which would more than likely have an E4OD trans. Burnout400m is correct, you could have an AOD or an E4OD. It would help to know what trans, you have.
Old 09-15-2012, 05:08 PM
I found the transmission code and it said it is a "T", which would make it an AOD transmission. I am wondering if there is a way to check the connectors, and how much would it cost to have the connectors replace.
Old 09-15-2012, 05:18 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Quote:
See,
Ford AOD TV cable adjustment - YouTube
Old 09-15-2012, 09:32 PM
So, if I got this right, since my truck's transmission is an AOD, it uses a cable and spring to sense when to change gears instead of a sensor. Alright then, I'll look at the cable to check for corrosion or if its loose when I change the transmission fluid tomorrow as it finally cooled down outside to work on it.
Old 09-16-2012, 11:12 AM
Nathanl25's Avatar
Nathanl25 Nathanl25 is offline
Nathanl25 is starting off with a positive reputation.
danr1,
I just have to thank you for that video, i literately just fixed an transmission issue that has been going on for at lest a year now. Just, by lifting a tab and pulling on that wire for a sec then push the tab back in place. my trans now shifts as smooth as silk rather than holding the gear way passed the prime time to shift (for normal driving) Tho I kinda liked it holding the gear when i miss treat the truck or towing something but i know how to fix that now.
And my transmission guy was going to charge me 150 just to look at it.
1988 F150 C6 hesitating when cold Cbartlett1988 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 01-21-2015 01:32 AM
quirky transmission greenstar 1999 - 2003 7.3L Power Stroke Diesel 26 12-15-2013 02:15 PM
NP 435 grinds gear in 2nd to 3rd shift hooperdoski 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-07-2013 10:55 AM
Transmission slipping in 1st gear. shawnvhs2003 1997 - 2003 F150 3 06-05-2011 05:20 AM
The Persistent Issue of My Overheating Transmission thekingofcows Clutch, Transmission, Differential, Axle & Transfer Case 8 04-14-2011 02:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
