Changing the complete exhaust system F150
MY vechicle is a 92 F150, 4 wheel drive, extended cab with 8 foot bed. The current exhaust system is 12 year old and rusting enough where I want to change it. I have never attempted to change it by myself before so I don't know how hard it would be to do or how long it would probably take.
My problem is I need to get it done in 1 or 2 days. All I have access to is a ramp stand and some floor jacks and my tools, roto zip, etc. enough to do the job I believe.
But how hard is it? How high do I have to jack the truck? Do I need a cutting torch? How long should it take to do the job.
Thanks a lot for your support.
Edit: I looked on Chilton's repair manual first and it didn't tell me much. That's why I'm here next.
Regards,
Larry
Regards,
Larry
exhaust
I can give a few suggestions. If you buy identical parts, its not too hard, but yoy need heat (a cutting torch) to heat up siezed fasteners, or for cutting. For a beater truck at work, I started with a new cat back exhaust removed from a brand new truck when they swapped to an aftermarket system. I sourced it on craigslist, and pickups have very similar dimensions, new or old, and usually some wiggle room. The system was 100% stainless and only $65
I had a muffler shop install it, and the installation was $50
Or a muffler shop could fab it by bending straight pipes and a new muffler. Shop around for the best price, as alot of times a shop can do it cheaper and quicker than you or I.
burnout400m, I am sticking with production unless there is some after market that is really good, improves performance and doesn't screw up the engine - something with a real track record over a long time. I don't want to take chances. Any suggestion?
I would be concerned about taking it to these midas or franchise muffler places. I don't even let them change my oil. I've had too many screw ups to do that- crossed threaded drain plugs, etc.
Regards,
Larry
Regards,
Larry
Regards,
Larry
Regards,
Larry
Regards,
Larry
Regards,
Larry
I'm planning on moving someplace that's a little more friendly for vehicle maintenance but finding some place that allows it can be pretty hard. My last apartment had a rule against it too except there wasn't a property manager on site so I could get away with it.
Burnout400m, yeah I would move too except that I can't for the time being. Money wasn't an issue before I got laid off four years ago from a lucrative job because of outsourcing. Now money is and I'm stuck for the time being at the place where I am living. In the meantime I'm getting my truck totally road worthy so I can make a dash for the exit as soon as I have a bite on a good paying job.
One thing I am still trying to find out is how high is acceptable for installation so I can do everything at once without finding out I didn't
plan this out well enough.
Regards,
Larry
Regards,
Larry
Back in the day I found out my local carx carried the same walker parts the auto parts store did, and could have it installed for less money than what they wanted over the counter at the parts store.
There are many skilled shops that do nice work. When you do it every day, you get good at it. Depending where you live, ask around and get a few estimates as a reference point, and see who you feel comfortable dealing with.
nikmish
12-21-2011 06:04 PM
