X codes and B codes are in
Well got the springs in, had a line on a slightly used set of X code springs but that fell through so now my 00' EX is sitting on new springs on all 4 corners. Ride is vastly better than the bumpstop bash I had before, nice solid truck now. My question is this, after checking on various surfaces I still have some factory rake, which I am ok with, the thing that my eye picks up on is the 1/2" difference from passenger side front to drivers side front, passenger side being taller. Will this eventually even out......I hope?
Pictures to follow as soon as it stops raining
I just put X's on mine on Thursday and noticed the same thing. I hope it will level out. We'll see. I had an inch difference immediately after install, but settled to a half inch after 24 hours. But, could've been the ground it was sitting on when it was measured. Yesterday, while sitting in the bay at work, only a half difference.
After a full tank of fuel and all my stuff back in the truck, she sits about 1/2" low in the rear. Can't tell it by the naked eye. She's still a little high on the front right, but so far only I notice it. I will gladly take the way she looks and feels now. And she drives/rides remarkably better!
on
Nah, you have to adjust it if you want it level on both sides. Take it for a drive and hit some bumps and dips then come back and measure from the wheel wells. Whatever it is then will stay like that because both springs weren't made the same and they aren't going to magically fix themselves.
Other thing I was thinking of doing was pulling the front spring packs out, taking them apart and swapping the bottom leaves from one side to the other, that might cancel out any difference, or make it worse.......
Factory rake front to rear I can deal with, side to side will drive me crazy. I build custom high end cabinets and my eye is trained for stuff like that
I bought this truck in February and it has a set of 305's with alot of life left in them, so due to that and budget, tires are not on the list right now, will probably stay with a 305 in the future just step up to a 17" wheel. 17 is a good compromise of road stability and airing down for beach driving. I love this rig even more
on
I was actually already contemplating doing just that, was gonna use the G code slapper spring and cut off the thick end, theres my 1/2". That gives me the option that if they do settle from weight and the drivers side is now too high, I can pull that piece out.
Honestly, I think with x codes and the B's as is would have put my truck perfectly level unloaded
Thanks for the compliments, really got lucky when I was shopping for a rig to replace the one that was totalled by a transit bus, this one had only 82k miles on her when I bought it, paint is great condition, a few small stains in carpet under floor mats, 2 small dents one in each bumper, no big deal.
Need spring education
I have an 01 EXC 7.3L 4WD and hope to replace springs in near future. Read a little about them but need more info on the options out there. When I got it, it had lots of sway in turns and bottomed out way to easily. Replaced the shocks first day I got it and not much improvement. Added Timbren Suspension enhancement, but that was basically larger bump stops, so it helps on tows and softens bottom outs, but doesn't do much for unloaded ride. What are the spring options out there and what is best for me? I don't need a cadillac ride, and don't mind a "truck" ride. I do tow at times, a 5000lb boat and a 10000lb camper. Need some beef in the springs to give me stability when towing that heavy camper. Thanks
