Blue smoke, need help! Not pcv or stem seals...
Hey guys. Thanks in advance for the help. In March of this year, I put together a 1994 F250 with the 5.8L. It used to be a plow truck and sat for a couple of years before I started on it. I've put about 10k miles on it so far and have only had these 2 issues.
1) Low RPM bogging. If I start out in 2nd or try to lug in a higher gear, the truck seriously bogs down to the point of moving me forward in my seat. It acts as if it's getting too much fuel. I would expect it to lug, but not bog down. I can give it slight gas and it'll lug just fine. Once the rpm's climb a bit, it picks up and goes great. I don't lug often, I know it's not good for the motor, but if I slow down for a light, I won't bother shifting.
2) Within the last 2 weeks, I've been getting a lot of oil smoke at idle and decel. That tells me it's a valve/valve seal problem. I replaced the seals and the pcv, but no change. The motor doesn't seem to start or run as if the compression was low. Would the oil be sucked in from valve guides? maybe an air intake gasket? I'm going to do a compression test today, as well as a vacuum and leak test for the intake gasket.
I can't think of anything else that would cause either of these problems. The truck has 4.10 gears, 2.5" exhuast with a gutted cat and glass pack muffler. New air filter as well.
Thanks again.
Thanks again.
Oh yeah...
Forgot to mention...
The only cylinder burning oil is #8, driver side rear. This is the only plug getting oil fouled. All others appear to be normal. The #8 plug comes out dripping in oil. I know this was common with older 5.8's with the pcv routed to the rear of the intake runner, but mine is routed in the middle.
Rings
Thanks again.
Thanks again.
I'm really hoping it's not rings. The compression test will answer that later today. If I understand correctly, if the rings are bad and I'm getting blow-by, I should see smoke on acceleration too. Is this accurate? I'm only seeing the smoke at idle and decel...
Thanks.
Thanks.
Did you try squirting some oil in there and running the test again? If the compression comes up when you do that, it will prove it's the rings and not something else like burnt valves or head gasket blown,,, It might be worth doing just for the heck of it.....
la350
03-10-2005 06:59 AM
