Help is this nut Left hand tread - Ford Truck Enthusiasts Forums
Old 09-08-2012, 04:54 AM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
fordf350camper is starting off with a positive reputation.
Hi i need to take the rear wheel hub off my 1957 f350 could you tell me are the large nuts that hold the hub on left hand tread as i cannot undo it.Thanks whats the best why to crack it free a large socket id so what size thank you Pete from the UK
Old 09-08-2012, 02:13 PM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
The lug nuts(that hold the wheels on) on the driver's side are left hand(1 1/16" socket, I think).
Everything else is standard thread on both sides.
Are you talking about the small axle nuts(1/2 or 9/16" socket) or the large bearing retaining nuts(over 2" socket.)?
Old 09-08-2012, 02:14 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Are you referring to the large nuts that hold the bearings in. They are not left handed that I know of but they do have a lock washer between them that you have to bend the tab back on to be able to remove the outer lock nut first. The inner (adjusting) nut shouldn't be that tight.
i don't know the size exactly, around 2 1/2 inches or so, I mean nearly 65mm!
Old 09-09-2012, 12:42 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Normal rt hand thread. I'm not really proud of it, but I always knock them around with a cold chisel. From the looks of most of them, I'm not the first owner to do this
Old 09-09-2012, 12:44 PM
1960fordf350's Avatar
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
Those nuts should be regular thread. Cold chisel and 3lb hammer is the only way I've ever gotten that nut loose. Go in about 1/4in from one corner and nice and easy start an edge. Once you've got a spot that you can push with, then give it a few good hits. Just make sure your not trying to turn the inside nut at the same time. I see on a previous post to bend the tabs back on the lockring, I forgot to mention that.
Old 09-09-2012, 09:02 PM
spurredon's Avatar
Quote:
I have used a chisel and puch as well in days of old. Lately, if I need to buy a tool I buy a tool. I guess it gives me a reason to take a break when I don't have what I need!
Old 09-10-2012, 12:15 PM
Thank you to all.Its so nice to ask on here to get the help.I have now got them off and it looks like the last owners knocked them off.Would you have any idea who would sell the nuts as these look a bit to damaged now.And who would sell the tabs you bend over.If not i will have to get a machine shop to make some.But i know i will be waiting quite some time.
Old 09-10-2012, 12:28 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
Don't use a sharp chisel or you risk destroying the shoulders on the nut. Actually a very dull chisel is a better choice of tools. I have seen bigger trucks with the left hand thread on the right hand side, long time ago.
Old 09-10-2012, 01:00 PM
Hi i have now got them off.I could use them again but if i could get some better ones i would fit them.Thanks Pete
What other gear box fits a 223 engine fordf350camper 1957 - 1960 F100 & Larger F-Series Trucks 5 03-01-2013 06:25 PM
Front Hub issue on 95 4X4 F150 70runner 1987 - 1996 F150 & Larger F-Series Trucks 11 12-05-2010 11:14 AM
39 pickup back spacing pjhjah 1947 and Older Ford Trucks 2 08-31-2009 09:35 AM
Oil leaking from my rear axle.How to stop it fordf350camper 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-10-2008 06:38 PM
Front hub nut on 2002 explorer twisted limb Explorer, Sport Trac, Mountaineer & Aviator 1 03-20-2006 03:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
