Need Help
Hi Sara and welcome to FTE! I don't own a Ford Explorer, but I would think the neutral safety switch is the first thing to check. Also, what does the shifter feel like when you take it out of Park and shift it into a gear? Is it loose? Can you get any other gear besides Drive? What about Reverse?
It may be the shifting linkage is loose or worn. I haven't looked on a Ranger or Explorer, but the linkage in the steering column may be the problem. It could also be underneath. Be sure to have the wheels blocked should you climb under your vehicle. A 2nd person would be a big help in finding the problem perhaps. One working the leaver while another in underneath looking. Like I said, be sure the vehicle won't roll when doing this!
Sara, The VSS or neutral safety switch/ Range sensor runs about $40. on rockauto.com Autozone online manual says the sensor is mounted on the tranny, this is different from the ranger it was mounted on rear axle above the pumpkin. ask around in the ranger/explorer forum and a few members there can walk you through diagnosing and how to replace it.
thagoldenb
12-16-2012 02:34 PM
