Knocking/shaking idle - Ford Truck Enthusiasts Forums
Old 09-07-2012, 05:31 PM
charz charz is offline
charz is starting off with a positive reputation.
So after a decent drive when I get to a redlight/stopsign/etc the truck will idle rough and shake but giving it a little bit of gas (1k RPM) seems to smooth it out however it doesn't throw any codes or the CEL. The truck is a 2008 F150 with the 5.4 and 90k miles.
I've searched quite a bit on this issue and I can't seem to find any real fixes other than swap parts out until something works and I've heard everything from filters to cam phasers or low oil pressure (I will be taking it to the mechanic to check the oil pressure)
so far I've:
Replaced the air and fuel filters
Changed the oil and oil filter (synthetic and oem filter)
cleaned the MAF and cleaned the throttle body
also is the 2008 equipped with an IAC Valve because I've read that it wasn't and I can't seem to find the IAC if it is.
Old 09-08-2012, 08:36 AM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Mine did this last week and for a few days and then a few days later when I hit 45mph or higher it starting shaking really bad and did throw a CEL. It turned out to be a misfire for me which was a result of a bad COP. At about 90k I had to change my plugs from misfires and the truck now has 97k on it so it was fairly easy to track it down. I would start with your plugs the 100k mark is not always correct it all depends on how you use the truck. I started having problems at about 82k with misfires and it got worse until I finally changed it but it never threw a code so I was not sure what the cause was.
Old 09-08-2012, 11:20 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Need a scanner that will read live data, it'll show you what cylinder(s) are having problems.
Old 09-08-2012, 12:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
No, the '08 is equipped with electronic throttle. A motor built into the throttle body controls the position of the throttle plate. It's controlled by the ECM. The accelerator has no mechanical connection to the throttle body.
Old 09-08-2012, 01:32 PM
Coskid's Avatar
Quote:
Good point I did not mention that. When my plugs were replaced they did a live data read out to show that I was having misfires on 3, 7, and 8 cylinders even with no codes being thrown. 8 needed a new COP at that moment while 3 was what I replaced last week. I guess 7 may go here soon on me but I can wait until it happens.
Old 09-08-2012, 11:35 PM
Quote:
This is a more or less just when I slow down off of a highway and end up at a stop light the thing shakes like hell but on the road I've noticed next to nothing shaking wise.
I'll probably borrow one this week and testto find out
Quote:
thank you, I feel slightly less stupid not being able to find it after digging around for it an hour
Old 09-09-2012, 08:43 PM
Coskid's Avatar
Mine started out the same way but the live data read out will tell you whats going.
Old 09-13-2012, 07:27 PM
the issue seemed to have went away for a few days until today it was doing it at a toll booth, I tried scanning it but when I rented the scanner I wasn't able to induce the problem .
I have spark plugs and the throttle body gasket in the mail so hopefully next week I'll do a total TB rehab and then change plugs(borrowed a lisle tool). For now I'm going to run some injector cleaner through it to help loosen up the plugs and it couldn't hurt.
Old 09-14-2012, 07:11 PM
ok well the poopoo has made contact with the fan...
This morning I went to leave for work and the truck was missing I put it in gear and it stalled out halfway out of my driveway I restarted it and it was really missing with the CEL on so I shut it off put it in neutral and pushed it back and crammed my tools into another car.
when I got home I let it idle so I can listen to it and it smoothed out but I still have a CEL tomorrow I'm going to pick up a scanner and a few coils and see if I can get the extractor off a buddy because my plugs came in.
I will be updating as I go because this is a very common problem it seems (3 threads about it on the front page) so I will keep everyone updated with a solution
Old 09-14-2012, 09:07 PM
Coskid's Avatar
Sounds good man I hope all goes well for you. If you run into a problem hit us up on weekends you can usually get a quick response.
Old 09-14-2012, 09:28 PM
Generally I know what I'm doing I just want to resolve this kink and get everything running smoothly you know and if I can help a few people with the same issue why not
I figured this morning the cam phaser went but can this even happen on the Post November of 07 trucks and the issues seemed to have resolved but I won't have any clue until I scan it tomorrow
Old 09-15-2012, 06:46 PM
I scanned it
codes
P0012 bank 2 vct
P0300 random misfire
P0302 cylinder 2 misfire
P0303 cylinder 3 misfire
P0304 cylinder 4 misfire
P2196 O2 sensor rich
Pending
P0010 vct connection
well now I'm stumped I can only think that the O2 sensor is bad
Update
I moved around and cleaned the coils and reset the ecu
started it up and it runs ok but still kinda off and I rescanned it and got the following pending codes
P0012
P0351
P2198
I did find one problem the connector for the coil was broken on one cylinder
Old 09-16-2012, 03:30 PM
so after doing a bit more work the truck is now driveable and sounds good but I still have a cel
down to two codes
P0340
P2198
how screwed am I?
Old 09-20-2012, 02:52 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
I wonder if a dirty/contaminated fuel system/injectors might have something to do with it?
Old 09-20-2012, 08:29 PM
Quote:
right now it's at the 3rd mechanic so I'm going to find out tomorrow what the verdict is, I personally believe it's a bad chain tensioner and my timing is off a tooth because I hope it's not a phaser
4.9 stalling when warm, difficult to restart. animator 1987 - 1996 F150 & Larger F-Series Trucks 8 Yesterday 11:39 PM
Help with high idle on 94 460? NotMatt 1987 - 1996 F150 & Larger F-Series Trucks 15 08-24-2016 10:18 PM
stalling,bucking when i hit gas after truck sits. Codycamper 1987 - 1996 F150 & Larger F-Series Trucks 6 10-16-2015 02:22 AM
Can I make my bronco run better? 1990, 351w ErrorS 1978 - 1996 Big Bronco 20 12-06-2011 10:14 PM
2002 Ranger 3.0 Starting Problems offlinepk Ranger & B-Series 7 10-25-2010 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
