Knocking/shaking idle - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-22-2013, 06:18 PM
friscofordguy friscofordguy is offline
friscofordguy is starting off with a positive reputation.
Charz, I'm having similar symptoms. What did your mechanic find?
  #32
Old 04-01-2014, 05:53 PM
charz charz is offline
charz is starting off with a positive reputation.
Quote:
I've just been running lucas in it and driving, I'm not putting another penny into fixing the motor if it stops working then I'll just drop a jasper in it.
  #33
Old 04-15-2014, 07:43 PM
bfl4 bfl4 is offline
bfl4 is starting off with a positive reputation.
Quote:
Originally Posted by charz View Post
So after a decent drive when I get to a redlight/stopsign/etc the truck will idle rough and shake but giving it a little bit of gas (1k RPM) seems to smooth it out however it doesn't throw any codes or the CEL. The truck is a 2008 F150 with the 5.4 and 90k miles.
I've searched quite a bit on this issue and I can't seem to find any real fixes other than swap parts out until something works and I've heard everything from filters to cam phasers or low oil pressure (I will be taking it to the mechanic to check the oil pressure)
so far I've:
Replaced the air and fuel filters
Changed the oil and oil filter (synthetic and oem filter)
cleaned the MAF and cleaned the throttle body
also is the 2008 equipped with an IAC Valve because I've read that it wasn't and I can't seem to find the IAC if it is.
I had the same problem on my 2004 5.4L had a rough idle, also noticed a rattling noise coming from the right side hub while driving, and my cruise control would work on and off. Turned out it was a vacuum problem. I replaced the vacuum valve on the driver side fire wall (~15$) and the vacuum reservoir that sits behind the battery, its a little black box that holds pressure found one at a local junk yard for 10$. When you change this out I would also look at the connectors throughout the vacuum lines to make sure they aren't clogged up. After I did all that my rough idle disappeared, hub noises disappeared, and my cruise control worked whenever I needed it too.
Good Luck
4.9 stalling when warm, difficult to restart. animator 1987 - 1996 F150 & Larger F-Series Trucks 5 Yesterday 11:42 PM
Help with high idle on 94 460? NotMatt 1987 - 1996 F150 & Larger F-Series Trucks 15 08-24-2016 10:18 PM
stalling,bucking when i hit gas after truck sits. Codycamper 1987 - 1996 F150 & Larger F-Series Trucks 6 10-16-2015 02:22 AM
Can I make my bronco run better? 1990, 351w ErrorS 1978 - 1996 Big Bronco 20 12-06-2011 10:14 PM
2002 Ranger 3.0 Starting Problems offlinepk Ranger & B-Series 7 10-25-2010 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
