Key tumbler fell out - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 09-07-2012, 01:51 PM
jtindale's Avatar
jtindale jtindale is offline
jtindale is starting off with a positive reputation.
Hello,
When I went to pull my key out of the ignition yesterday the key got a bit stuck and when I jiggled it a little to pull it out the chrome bezel that locks the tumbler in fell out. Now the tumbler is out as well and I cant figure out how to get the tumbler in and lock the bezel in place.
I see a pin on the bottom of the ignition cylinder that I should be able to push in and pull the cylinder out but I cant seem to push the pin in at all.
Can anyone help with this? Thanks in advance!
Old 09-08-2012, 04:38 PM
Expypate Expypate is offline
Expypate is starting off with a positive reputation.
The pin will only push in when the ignition is turned to the on position. Reach in and turn the switch on with a screwdriver and you should be o.k. If the pin pushed in while in the locked position it would be way to easy to steal the truck.
I would replace the ign plug if it continues to happen.
Old 09-08-2012, 10:57 PM
jtindale's Avatar
Thanks Expypate! I did that and went to Ford to get a new cylinder. There was a tab broke off in the cylinder that prevented the chrome bezel from holding the tumbler in place.
Old 09-09-2012, 12:05 AM
I'm glad you got it back together. I was a locksmith for years, but now work in the wholesale side of the business. Amazing what you forget when you don't do it everyday.
That annoying door chime is finally quiet! Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 130 07-21-2015 10:54 AM
Re-keyed my door locks How-to write up Duckmang 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-20-2014 04:15 PM
Ignition Switch / Tumbler mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 12-23-2012 08:33 PM
Ignition switch key tumbler removal kjvforme 1961 - 1966 F-100 & Larger F-Series Trucks 10 08-15-2009 12:12 PM
Ignition Key Tumbler Problem 2009 Convert 1987 - 1996 F150 & Larger F-Series Trucks 5 04-29-2009 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
