GP relay on a switch....
Leave the PCM ground in tact.
I've got my GP relay switch that adds the ground. One pole on the switch goes to the GP relay and the other pole on the switch goes to a ground. That way the PCM can still control the GP relay in a normal way and I can over ride it and activate the relay when I want it too.
My switch in the off position lets the PCM do its thing normally. After the first start of the day I flip mine off so the GP's can't run. I just feel its a waste of energy and wear and tear on the GP's to let them run when the motor starts fine without them. This is mostly for short trips around town when the OT doesn't get up there to stop them running.
Here is a link for manually controlled GPR from last year
https://www.ford-trucks.com/forums/1...g+relay+switch
on
1 Post
