Air bags or leaf
Air bags or leaf
I have a question I tow a 8500 travel trailer and have a reese strait line hitch rated for 15,000 lbs spring bars. I am getting alot of tailer sway and I think I have the hitch setup right. Watching the rear suspension last time towing seems like it wants to move up and down alot. So I was searching and found alot of people are putting air bags on the new trucks because of the leafs being so long for the RIDE. Would it be better to add the Firestone air ride or have another leaf added?
On a side note, as I'm sure you already know, the air bag system will not increase your load capacity/rating. Just a standard disclaimer. Please let me know if you have any questions. Thanks!
If you can give me your year, make, model, and if it's a 2wd or 4wd, I can find a kit that will work for your application. Adding air springs to the rear of your truck will give you the best of both worlds. Inflate the bags when carrying a load to eliminate the squat, correct headlight aim, eliminate trailer sway, improve braking/steering, and more. Deflate the bags when riding empty for a softer ride.
tire pressure?
make sure tire pressure is good and not minimum psi. i run air bags on a big 4wd and just love them. running for over 10 yrs now. the longer leafs are great for ride but they can move around a little. what shock are you running? make sure shocks are good to go. start with the simple scary stuff then work up to the expensive stuff.
Your truck would use our most popular kit, part number 57396. You can learn more about it here: LoadLifter 5000; Leaf Spring Leveling Kit. And check out the awesome rebate offer we have going on here: Air Lift Rebate. If you have any more questions let me know. Thanks!
I have a question about your hitch? I assume that you have a weight distributing hitch? When you have your camper hooked up is the truck sitting level, or is it squatted in the rear end? We had had a camper for years and I always hooked up the camper, let the jack down, and then tightened up the bars as tight as I could get them. This would pick up the rear end some, but it still would not be level. With the F-250 I pulled it with it would still sway when a trailer truck passed me. When we bought a new camper a couple of years ago we had to go through the new customer walk through. One thing that I did learn is that for your hitch to work right your truck needs to set level when it is hooked up. This puts more weight on your front axle and reduces sway. To do this hook up your ball, then jack your trailer jack up as far as you can easily get it, pulling up the rear end of the truck. Now attach your bars as tight as they will go. Using this procedure I was able to get a couple of more links on my bars and made my truck set completely level. I was amazed at how much better the truck drove. I am now pulling a 29ft 8,000 lb loaded camper with a F-150 and do not have any trouble with sway, but I did have to add a sway brake on my hitch when I downgraded to a half ton. You might already be doing this, but if not give it a try; you will probably be surprised how much better your truck handles your camper.
BobbyJ
03-09-2008 08:04 PM
dtpatt2
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-24-2003 01:30 PM
