Should I be satisfied with this alignment result?
I asked the tech to get everything zeroed out, but he said when he changed one thing it would change another. I feel like he basically gave up, and he was not familiar with the truck at all which gave me a warm and fuzzy feeling. Cost 100 bucks.
I know I have taken my vehicles back in on a different day and got a different tech to work on it. That can be good, but also could make it worse. Can't see where you went, but most shops will have a guarantee on the alignment. If you are not happy or suspect it could be done better then take it back until you are satisfied. The shop works for you!
on
Take it back. If it is too worn here and there they can't do it but they have to tell you . I do my own with levels, strings, sight , etc and it is always fine. It's not the rocket science it appears to be.
And why zero it out? How is he going to zero the built in camber and caster? Something wrong with the stock specs? Did it track well and wear the tires well? Are all the front end parts good? That showed 2wd is yours 4wd?
How does it drive? I'd worry less about what a piece of paper says and more about how it feels or if it wears the tires funny.
If he's having issues with the reading staying constant, it could be worn tie rod ends, or just an incompetent tech. I took my truck to a shop 3 different times trying to get them to fix their $100 alignment and it still didn't feel quite right. I finally gave up on them and went to a different shop and paid for another alignment. That made all the difference, and I've been fine since.
Tires are better off too when they are perfect and require no weights to balance them. But most of us are plenty happy with a tire that's close enough once a few weights are added.
on
on
It's really not that complicated. All you can do on the 4wd is set the toe in and I can do that in minutes with a tape measure and sighting with the back wheels. If you have to get special eccentric bushings for the upper BG you probably have worn parts somewhere which have to be addressed before any aligning will work. After your parts are all good, you can't ask for more that easy steering, good tracking, and good tire wear. It's kind of like losing weight; If your pants feel like they are a little looser and the buckle went up a notch, you are loosing weight and no need to look at the scale every 4 hours.
I have always done my own alignments with almost no tools involved but I'm not going to get into that because bah humbugs will want to argue. F-350 6 has the idea, read that post again.
http://www.allpar.com/fix/alignment.html
http://www.ehow.com/how_2214833_adju...alignment.html
http://www.hotrod.com/techarticles/c...e/viewall.html
RedDirtLandscaping
07-11-2011 09:29 PM
03F2507.3
03-31-2009 08:05 PM
BufordinAL
06-13-2006 08:25 PM
