Oil pan/rear main seal '84 f150 4.9L
So, does anyone know a cost range to have a mechanic change a rear main seal and gasket? Tranny will have to be pulled. This thing is leaking bad. It was only leaking a little, then I went and screwed with it, now it's undriveable. Yay me. Has anyone ever had this done?
Thanks,
Derek
Thanks,
Derek
My local Trans shop said $350 to pull trans and replace the rear main seal, and that included the materials like the oil and etc. Yeah pretty good price because he was adding about $50 discount. Forgot to add, my estimate was for the 4x4.
If it's just the pan gasket, change it. People seem to blame the "rear main seal" way to often in my opinion. I would replace the pan gasket, and if the rear main does leak a little bit, I would try some of that stop leak stuff first. It has chemicals in it that attack the rubber and make it swell up and soften, sometimes stopping the leak.
The pan gasket (lifting the engine up) should be a separate operation from the rear main(taking the tranny out). I don't think you would gain anything by having them both done at once.
It's a miserable job, that's why he is balking at doing it. Working in a tight dirty area with oil dripping on you continually.
I would look your truck up on Rockauto or Autozone's site and see if there is a one piece gasket available.
If you do attempt it yourself, don't take short cuts and try to clean the pan up without taking it completely out, risking stuff falling inside it. We have had several people do this on here and end up with no or low oil pressure from all the debris getting sucked up in the oil pump pickup screen.
Just thought I would update you guys in case you were curious about the result.
Here's what I ended up with: new rear main seal, new oil pan gasket, new clutch.
The main bearing cap was installed backwards by the last owner apparently. The clutch was chattering, thus toast! Also, the main bearings are down to brass! I paid $1159 to get it fixed and find out that the engine is worn out. There's also a hefty groove in the crank.
On the bright side, I'll be getting a new truck next year!
Yes, the oil pressure, temp, and fuel gauges are provided their working voltage by the Instrument Voltage Regulator (IVR) and they are notorious for fluctuating voltages, which makes the readings fluctuate. Get an aftermarket unit and tee into the oil pressure port such that both the factory sender and the new gauge are hooked up. Dad's 351M with 145,000 miles on it goes to 70 PSI when the engine is cold, but after about 20 minutes of driving the pressure gets down to about 40 PSI on the road. And, it'll drop to 20 idling. But, that's adequate pressure so I'm not worried.
Diesel 724
43
09-09-2011 08:58 PM
Bullride_101
09-22-2007 10:39 PM
dakonthemountain
07-12-2006 02:33 PM
