2005 6.0 no start - Ford Truck Enthusiasts Forums
2005 6.0 no start
Old 09-06-2012, 12:32 PM
Kevin L Phelan Kevin L Phelan is offline
Kevin L Phelan is starting off with a positive reputation.
Unhappy 2005 6.0 no start
My 2005 6.0 had the egr cooler go bad and I replaced it with a n oem unit. The truck was down for 4 months. It has no codes. It cranks but will not start. It has 1345 psi Icp. Passed Koeo test. what am I missing. I drove it in the shop running rough but it would run then.
Old 09-06-2012, 12:46 PM
m-chan68's Avatar
m-chan68 m-chan68 is online now
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Injector(s)???
Old 09-06-2012, 02:06 PM
WIKD WIKD is offline
WIKD is starting off with a positive reputation.
Make sure the batteries are up. Every time mine has a no start lately it fires up as soon as you put a battery charger on it. Both batteries show at or just below 12 and that still isn't good enough.
Old 09-06-2012, 02:12 PM
Low Key Low Key is offline
Low Key is starting off with a positive reputation.
Got fuel pressure ???
Old 09-06-2012, 02:49 PM
Injectors click like normal. Ficm voltages are 48 on the scan tool. It ran perfect until the egr
cooler went . It was driven 10 miles home and pulled in the shop. The engine was loading up as it idle into the shop. It hasn't started since.
Old 09-06-2012, 04:55 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
check the upper fufel bowel for Fuel
Then check to see what FPW is
FPW=Fuel Pulse Widthh
any DTC come up ????
How Fast does it crank 150rpm????thats what it needs
Old 09-06-2012, 05:38 PM
It has new fuel filters. Yes there is fuel in the bowl. If you crack the return line there is fuel. It has new batteries with ample voltage. It cranks faster than 150 rpm. I have had a Snap-on Solus scan tool monitoring it I know that I have to charge the batteries after each session. It puffs smoke and hits on about 3 cyls. It almost started, then I melted the starter down cranking it for longer than 10 sec. intervals. It is aggravating. I have worked on more than a few of these, but never had this kind of trouble.
Old 09-06-2012, 05:39 PM
No Benny, no DTCs at all.
Old 09-06-2012, 05:49 PM
BLADE35's Avatar
well might be good to see if ICP is really 1345psi
do you have mechanical press gauge
guess im saying is the ICP sensor good
Old 09-06-2012, 05:50 PM
BLADE35's Avatar
oh ya check sync
FICM Sync
CMP/CKP Sync
Old 09-06-2012, 05:52 PM
m-chan68's Avatar
Do ALL EIGHT injectors buzz/click when you run a KOEO injector buzz test?
Old 09-06-2012, 08:48 PM
Syncs are good. I may have to borrow a gauge that reads that high pressure oil.
All injectors buzz and click. I put a new starter on it and it cranks about 300 to 350 rpm's.
I may get a Known good sensor and try that. It is puffing a little out the tail pipe and seems like it almost is about to start. I really do appreciate all the help so far I have got from you guys.
Old 09-06-2012, 08:57 PM
m-chan68's Avatar
Wow, that sure is cranking awfully fast. Does this engine have good compression?
Old 09-06-2012, 09:44 PM
Delawhere?'s Avatar
Delawhere? Delawhere? is offline
Delawhere? is starting off with a positive reputation.
I don't have an answer for your problem, but I'll be reading the info because mine wouldn't start today either. Cranks over, almost starts, puffs a bit of smoke and then just turns over. Wait awhile and crank it again it almost starts but then back to cranking again. Just had it towed to the Ford truck service center to find out how much this will cost. I am just about at the end of my patience with this 6.0L it's been on the hook one too many times. Looking at the 6.2L for the next one.
Old 09-09-2012, 08:01 AM
Delawhere?'s Avatar
ficm replaced
Just got my 6.0L back from the shop and they said the FICM was bad. Cost $1,050 to get it out of the shop but at least it runs for now.
6.0 trouble starting Nphip 6.0L Power Stroke Diesel 3 08-23-2015 01:04 PM
No power on my 2005 6.0 2-6.0's 6.0L Power Stroke Diesel 27 04-06-2014 09:51 AM
6.0 starting problems geneva1 6.0L Power Stroke Diesel 13 01-15-2014 05:00 AM
2005 F350 Front coil spring swap Rhatler 1999 to 2016 Super Duty 3 04-13-2011 01:31 PM
Dyed Diesel in 6.0 Country4.2 6.0L Power Stroke Diesel 6 03-15-2007 03:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
