what mpg should I expect from my 2000 7.3 4x4 Excursion - Ford Truck Enthusiasts Forums
Old 09-06-2012, 12:36 PM
Roger Y Roger Y is offline
Roger Y is starting off with a positive reputation.
Question what mpg should I expect from my 2000 7.3 4x4 Excursion
I am trying to determine why my mpg seem lower than when I bought the 2000 4x4 Excursion new, everything is still stock and I have 180,000 miles on it. Currently i am getting 12-14mpg locally and it doesn't seem to get much better on the highway. A few years back i called the Ford dealer and they tried to tell me the sudden drop-off was due to fuel changing in the winter. I am getting older, but I could swear that I was getting between 18-20 on the highway while cruising at 70mph back then on the long hauls. Just came of back from a 2000 mile trip and don't think i broke 16 while driving 95% highway miles.
What are you guys expecting from your similar set-ups? Am I just losing it in my age?
Old 09-06-2012, 01:10 PM
jd58980's Avatar
jd58980 jd58980 is offline
jd58980 has a good reputation on FTE.jd58980 has a good reputation on FTE.jd58980 has a good reputation on FTE.
I am getting between 14-16 around town and a steady 18 on the highway. Have not taken Ex on a LONG trip to experience a full tank of fuel mileage.
But drive the Ex 500-600 miles a week.
Old 09-06-2012, 01:29 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Same here.
Stewart
Old 09-06-2012, 01:31 PM
Stewart_H's Avatar
Do a search in the 7.3L forum. There are maintenance items you can do to your rig to ensure the best MPG.
Stewart
Old 09-06-2012, 01:39 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
most problems on the 7.3 is the exhaust backpressure tube gets clogged up or the sensor is clogged. A simply cleaning of the sensor and tube will help with power and MPG. The second problem is the stock fuel tank pick up line, the stock setup uses this weird feed return setup that mixs the two so your feed is sucking air bubbles from the return and it makes the motor loose power
Old 09-06-2012, 01:42 PM
heres the fuel pump fix, its called the Hutch mod
Driven Diesel Fuel Tank / Pre-Pump Kit
Old 09-06-2012, 01:46 PM
Old 09-06-2012, 08:07 PM
B-Xcurgin's Avatar
B-Xcurgin B-Xcurgin is offline
B-Xcurgin is gaining momentum as a positive member of FTE.
12-14 Around town 18 highway. then I Got this:
Riffraff Diesel: RDP 6637 Filter Kit
Now 14-16 around town and I got 22 highway two weekends ago on a 5 hour trip. Boo Yaa
Old 09-06-2012, 08:09 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Not to be a downer, but I promise a 6637 didnt give you 22mpg.
Old 09-06-2012, 11:26 PM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
To the OP: Have you changed anything on your truck? Tires? Springs? Anything? Is your speedometer/odometer known to be accurate, and has it always been? I noticed mine was reading about 3% slow, and corrected it with AE and a GPS. My "mileage" immediately jumped. Of course, it really didn't change, at all, I was just measuring it more accurately.
For what it's worth, I get 13-14 around town, and 16-17 on the highway.
Mark
Old 09-07-2012, 09:20 AM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Quote:
But be careful! I just cleaned mine and I believe I may have damaged the sensor since I have been getting a drop in MPG's since the cleaning!
Old 09-07-2012, 11:25 AM
BuiltFordTough!'s Avatar
BuiltFordTough! BuiltFordTough! is offline
BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.
Out of all the mods I have done the best increase in MPG is to run "Off Road" diesel. It makes a HUGE increase.
Old 09-07-2012, 11:32 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
The Lie-o-Meter strikes again! My ex, all stock gets 18-19 highway. I Dont have a heavy foot and I like to keep the rpms at or under 2000. Hand calculated I avg 18.5 highway. City 14.5
Old 09-08-2012, 09:35 AM
B-Xcurgin's Avatar
Quote:
Yeah its probably not accurate but before the I installed I never according to the Lie-O-meter got better then 17 so even if it is off I'm still getting better milage. thats what I was trying to say.
Old 09-08-2012, 10:50 AM
fin reaper fin reaper is offline
fin reaper is starting off with a positive reputation.
Hand calc'd yesterday 15.3 little town/mountain highway.
2003 F250 4X4 PSD - How do I reset the "Average MPG" caluclator? Cecil_Stringer 6.0L Power Stroke Diesel 8 11-11-2015 09:54 AM
think I made a huge mistake... Davidvc1964 1999 to 2016 Super Duty 20 07-05-2013 03:59 PM
First Tow with 6.2 kmonty2 6.2L V8 35 07-25-2011 11:27 PM
04 5.4 4x4 SuperCrew Gas Mileage SUCKS!!! rwdfan 2004 - 2008 F150 14 11-07-2010 07:54 AM
'00 5.4 4x4 only gets 12.5 MPG average Rescue50 1997-2006 Expedition & Navigator 8 05-20-2002 08:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
