Project: 4Spd thread
Well, I bit the bullet and picked up a T19. Came out of an 85 F350 2wd with a 460. It's a 5:1 first gear. Of course, the salvage yard cut the shifter.
Came with the aluminum bell as well. I figured I'd start a project log for the swap. Going in my F100
This thing is monstrously heavy.
For a short time I had an NP435 in my truck after converting from auto, but then swapped for a close-ratio T19, 4:1 low gear.
For me (very hilly area), it was a HUGE improvement over a granny low trans because it eliminated the big jumps between gears, giving four, fully usable ratios.
There are different T18/19 shifters, with shorter & longer fingers below the ball.
Novak Conversions have new replacements in both types, but with some 5/8" rod, your shifter can be repaired.
Well, was at it today.
Here's the donor truck.
79 F350 2wd with a 400. Holy beast this truck is...
I may as well post questions as I go along.
1.
What is this box?
That's the harness going into it.
2.
This OMG two piece driveshaft.. How does it come apart in the center? Was quite comical driving home with it hanging out the windows of my car.
3.
This F350 uses this cross member with the 400.
My F100 has this currently with the 460.. the straight across unit.
Which one do I use? (of course, my F100 frame is no drilled at all for that gullwing style crossmember.
4. Do these trucks have a clutch interlock switch at all, so you can't start the truck without the clutch pedal pressed?
1.
What is this box?
2.
3.
That T19 you have is setup for a two piece driveshaft, I don't think there is any way to convert it to use a one piece. I hate to say it, but I think your going to be stuck building or modifying a crossmember to mount that carrier bearing.
There weren't any clutch interrupt switches on these trucks! If you want you can wire one up using the old neutral safety switch.
And yes, the drive-shaft should come apart in the middle, the whole slip yoke should slide off. Just mark it with a piece of chalk so it goes back together on in exactly the same spot.
Sam
Sam
You wont need the 2-piece d-shaft with a short bed, but because of the bolt on yoke on the trans you'll need a d-shaft with a stub and slip yoke to install/remove it,
what size u-joints are you running most 2wd f350's have a 1350 series joint... might have to change yoke on the rear end,or use a combo u-joint but I'm not very fond of those.
