What good is an Aerostar - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 09-06-2012, 09:06 AM
RojoStar's Avatar
RojoStar RojoStar is offline
RojoStar is starting off with a positive reputation.
Old 09-06-2012, 02:49 PM
Jose A.'s Avatar
Jose A. Jose A. is offline
Jose A. is gaining momentum as a positive member of FTE.
just you wait till you see what I can load in mine.
Old 09-06-2012, 03:36 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
Is that a shorty? Did you also bring the picnic table?
Impressive all the same.
The most I ever hauled was myself with 3 of my friends, our mountain bikes (they were huge), all our gear (they had body armor), food and drinks for a day in the Santa Ana's. I took out the middle bench and moved the rear bench into its place, so we rode in comfort. But mine is an extended body.
Old 09-06-2012, 09:04 PM
CourierYVR's Avatar
CourierYVR CourierYVR is offline
CourierYVR is starting off with a positive reputation.
As a courier, I haul that amount of cargo on a daily basis.
Could this be why the brake rotors warp on a monthly basis?
Signed,
A person frustrated with continually warping brake rotors.
Old 09-06-2012, 09:23 PM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
That's great only one trip to the dump to get rid of the trash and the stuff in it.
Old 09-06-2012, 10:23 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is online now
93nighthawk is starting off with a positive reputation.
man, that looks like fun! b
Old 09-07-2012, 07:33 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
What good is an Aerostar?
nice thick steel body to keep the bears out while van camping.
they can have the bread, peanut butter and marshmallows in the storage tubs shoved under the back of the van. 400lb bear can lift the rear of an Aero, don't ask how I know.
don't do like I did and get a travel trailer to pull with the Aero.
gives the wife more room to take more s?*&
Old 09-07-2012, 07:35 AM
Jose A.'s Avatar
ok, I don't like bears, especially if they scratch my pristine '97 Aerostar paint.
Old 09-07-2012, 08:28 AM
dougielx dougielx is offline
dougielx is starting off with a positive reputation.
I can fit my 400lb streetbike in the back easily, just take the mirrors off and drive it up the ramp!
Old 09-07-2012, 09:35 AM
Jose A.'s Avatar
Quote:
Originally Posted by CourierYVR View Post
As a courier, I haul that amount of cargo on a daily basis. Could this be why the brake rotors warp on a monthly basis?
Signed, A person frustrated with continually warping brake rotors.
get the thicker Duralast rotors from Autozone with Lifetime Warranty and get them replaced free everytime they warp, eventually Autozone will get the message.
Old 09-07-2012, 06:03 PM
The_Ford_Driver The_Ford_Driver is offline
The_Ford_Driver is starting off with a positive reputation.
wait till I pack mine... will be moving shortly...lol
Old 09-07-2012, 08:35 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Replace the sticking calipers if you want rotors to last..Also the rear drums will warp because of the emerbrake dragging. Seems like rotors.Ask how I know..
Old 09-08-2012, 12:16 AM
CourierYVR's Avatar
Quote:
They are all just a chuck of cast iron made to resemble a brake rotor.
I checked the cheapo AutoZone Duralast rotors, which are made in China, and the warranty says 2 years. Other users have reported they warp after about one month of usage.
I bought another new set of rotors. They are Raybestos Professional Grade rotors. I also got the matching Raybestos Professional Grade semi-metallic brake pads (god help me!).
Old 09-08-2012, 12:31 AM
CourierYVR's Avatar
Quote:
How does a person know if he may have sticking brake calipers?
As for the rear drum brakes, I kinda suspect they are only used for when the parking brake lever is actuated. I did a test today while coasting down a very long mountain road using only the parking brake. The rear brakes did not have enough power to stop the vehicle, but they did have a little power to slow the vehicle down only a little bit.
I am kinda of thinking the problem with the Aerostar brakes is not the front brakes, but rather the rear brakes, or the lack of the rear brakes power, or the lack of the rear brakes coordinating themselves with the front disc brakes.
Old 09-08-2012, 03:42 AM
xlt4wd90's Avatar
The high center of gravity causes forward weight shift, unloading the rear tires, under braking. That's why there is a RABS on most trucks; the old types were levers attached from the rear suspension to a pressure valve to the rear brakes, and the new types use electronic sensors and actuators. This is why a more powerful rear brake will not really help.
Sliding door handle assy, tune up RojoStar Aerostar 4 06-26-2016 06:48 PM
Steering wheel wrap RojoStar Aerostar 1 03-09-2016 10:06 AM
Explorer brakes on an Aerostar, project notes. RojoStar Aerostar 22 10-11-2015 05:40 PM
Rear sway bar install RojoStar Aerostar 32 03-27-2015 04:32 PM
BBK throttle on a Vulcan RojoStar Aerostar 1 11-27-2013 11:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
