Freestar power door locks and window - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 09-05-2012, 07:57 PM
400Nut's Avatar
400Nut 400Nut is offline
400Nut is starting off with a positive reputation.
I'm Having issues with my wifes Freestar. Power door locks fail to operate on a regular basis. The passenger side window as well. With the locks, the drivers door switch works fine, but not the passenger side. Sometimes the drivers switch will only actuate the drivers door and none of the others. Then sometimes everything works fine. With the window, the passenger side switch will sometimes work and sometimes not work. I'm looking for any helpful information before I tear into the door panels. All responses are greatly appreciated.
Old 09-05-2012, 08:06 PM
Muffinman Muffinman is offline
Muffinman is starting off with a positive reputation.
Try pulling the switch first and see if its working right. Some times the plastic anchor snaps and it flops around.
Old 09-06-2012, 08:45 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Unfortunately the Freestar has almost nothing in common with an Aerostar other than its a Ford so its might have similarities in the way wiring is made. The Freestar is more like the Windstar, which is similar to a Taurus. I would check the connectors, maybe clean them with some electrical parts cleaner. Even though they are supposed to be shielded from exposure to water, connectors inside the door are more likely to have corrosion than many other connectors.
Old 09-06-2012, 02:44 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
Or it could be fraying of the wires just from the regular opening and closing of the doors in everyday use. It's very irritating, as these little breaks are somewhere in those bundles of wires going between the door and that little hole in the jam through the accordion hose, and very hard to track down.
2000 Crew Cab Drivers Side Door Lock Question stowbilly96 1999 to 2016 Super Duty 3 11-09-2016 12:47 PM
2004 Freestar power door lock problems old-dad 1968-2013 Full Size Vans 2 02-24-2016 09:08 AM
Need help, 2004 Ford Freestar, passenger side power window does not work. Gregs69GTO General Automotive Discussion 0 05-15-2008 07:11 AM
Power Door Lock 97 Explorer jonboy88 Explorer, Sport Trac, Mountaineer & Aviator 20 06-12-2006 03:35 PM
Door lock/window switch Problems kable Electrical Systems/Wiring 2 08-23-2004 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
