cracked steering knuckle dana 60, help locating replacement
I got a crack in my drivers side steering knuckle on my 78 dana 60 front end, I tried welding it once but it cracked when it cooled. can u buy replacement knuckles? and where?
OEM D60 knuckles show up on ebay for $200/<acronym title="Page Ranking">pr</acronym> but more often than not the DS knuckle already has the infamous 'crack and repair'.
Aftermarket knuckles are available for around $300/ea and they're much more beefy and stout than the oem D60 Ford knuckles.
is there a way to repair them other then gouge it out and weld it up like i did? i welded it slow and let it cool between passes but it still cracked.
Im in canada and that $300 will turn into close to $500 by the time its at my doorstep, but what brands are there out there that are direct bolt in? im seing one here that uses a different tie rod end.
