3.03 3-Speed Transmission
Old 09-05-2012, 01:08 PM
jmacr12's Avatar
jmacr12
jmacr12 is offline
I've got a 1970 302 with a 3 speed. I'm looking for a manual to help me with a rebuild. Anyone know where I can get one? Its a RAT H2. Thanks in advance.
Old 09-05-2012, 01:33 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Parts:
Tremec 3 Speed Manual Transmissions Rebuild Kits & Parts 3 speed | Tremec rebuild kits - Drivetrain.com
Video, don't worry, they are all very much the same inside:
The rebuilding of a Ford 3 speed manual Transmission « Average Guy's Car Restoration, Mods and Racing
Exploded view:
http://www.fordification.com/tech/images/3spd_303.jpg
Old 09-05-2012, 11:45 PM
orich's Avatar
orich
orich is offline
I've found that many of these type of 3 spd have rear main out put shaft bearing failure. Fixed just by removing rear tail-shaft housing. You'll need snap-ring pliers & a gear/bearing puller a piece of pipe to install the new bearing as a driver over the main shaft. Use old bearing or lager washer against new bearing as not to damage it if pipe is to lager. Maybe pipe 10-12" long. Can't remember length any more..Replace front & rear seals. But if tranny is jumping out of gear then you'll have to pull it all apart.. orich
chetspencer
11-28-2013 02:37 PM
F-250 WARHORSE
09-07-2013 06:49 AM
FLN
07-10-2011 08:10 AM
ol-blu
1999 to 2016 Super Duty
08-03-2010 04:03 AM
Haaser
13
08-02-2005 12:38 AM
Quick Reply: 3.03 3-Speed Transmission
