Search for a used F250,Extended Cab, Short Bed,4X4
Hi All
I currently have a 2005 F350 SD, Crew Cab, Diesel, 4X4, Long bed, DRW with a 410 rear end. I tow a 35 foot fifth wheel that has a GVW of 14,500 lb. I am looking to down size to a travel trailer with a GVW of 7500 lb. I would like to buy a 2005 or newer used F250 SD,automatic,diesel,4X4, extended cab,short bed. My question is does anybody know of a web site I can go to and verify the equipment and accessories of a particular truck using the VIN#, any help would be greatly appreaseated.
Window sticker look up:
http://www.inventory.ford.com/servic...er.pdf?vin=xxx
Replace the xxx with the VIN you want to look up, for example:
http://www.inventory.ford.com/servic...7W2BTXCEA20702
If you find a VIN, you can pay a dealer to run an Oasis report for you and find out what kind of warranty work was done on it, and read this thread before you buy a truck with the 6.0L diesel:
https://www.ford-trucks.com/forums/9...used-6-0l.html
Hello Grullman, I am not quite sure on a website to go to as far as what options, gearing a truck has but i know there's a FAQ on the super duty fourm you can use when you find a truck, use the codes on the door sticker for the axel! anyway i hope i helped a little, happy hunting. Oh i see texastech has you in the right direction
