Dual Fuel on a '88 F250
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->
I just purchased an '88 F250 4X4 351 5spd that has a full propane conversion, for greater flexibility I would like to convert it to dual fuel. The installer used an Autotronic 5910 Dualcurve and I am looking for info from anyone that has expirience with these units.
From what I can see on page 7 of the installation manual:
http://www.dualcurve.com/5910-INST.pdf
all I need to do is wire in a switch and I should be already to go, can anyone confirm or add to this.
I was also thinking that as these unts are no longer available new maybe I should try and find one or two extras in case my dies.
Thanks, Greg
<!-- / message -->
Thanks, Greg
<!-- / message -->
If the gasoline injectors, fuel pump and tanks are working go for it, you a 3-way switch that will allow you to switch back and forth. What mixer/system does it have on it?
If it is an Impco CA425 you will need to rig up a solinoid to apply vacumn to the top of the air valve when you are on gasoline or it will run really rich due to restricted airflow.
Redneckfordf2502002
11-06-2012 07:22 PM
GregonVI
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-04-2012 10:46 PM
82F100SWB
10-28-2007 08:17 PM
gsx
06-12-2005 04:34 PM
bigbluetruck
11-14-2002 03:05 AM
