You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I need to replace my rusted out Painted Nerf Bars. I'm looking at Stainless Steel ones, and have some questions. One style has what looks like painted brackets, which wouldn't be a problem, I'll just undercoat them. They also look like they have adapters made of painted steel in the ends of the bars. Anyone have this style? Any problems with the adapters rusting out. The other ones advertise Stainless brackets too. I can't tell how this would attach to the vehicle, so if anyone can clue me in I'd appreciate it. Thanks.
I've only played with Westin, DeeZee and Manik. They have what looks like brass and aluminum inserts or just have threaded bar inside the end of the tube.. Usually the brackets are fitted to select vehicles, so no adapters are needed. Just insert some speed nuts, hold the bracket up and run a bolt in. Then bolt the bars to the bracket.
Now another thing to look at is polished Stainless or chrome plated. Polished will most likely be bare and will need to be regularly waxed to keep them shiny.
I got a set of Ionic's. and they are on the truck. There was a sale on them 100 off, and zero shipping. I really like the way they are attached, they use bolt plates that go inside the sill rails.
I put on Nasta stainless system, all s/s i believe and love them.
__________________ Master Chief, HMCM(FMF/AW) JOIN US http://www.nyfirearms.com/forums/ind...eferrerid=1780 The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
I have a set of the westin SS nerf bars and love the look of them. Ive had them on for about 2 years now and no signs of any rust or any damage. also they are lifetime warranty.
-AJ
__________________ AJ PAA Member #101 01 XLT LB F-250 Supercab 4x4 7.3L, GPR led, 6637 w/cover, Marinco Mod, Skyjacker shocks/Steering Stabilizer, DP tuner, muffler delete, Pro Rack, toolbox w/ custom brackets, Westin Platinum Oval Steps, XM satellite radio, tow mirrors, zoodad, RR IC boots, RR Plenum Inserts, RR HPx, foil delete, Isspro EV2 EGT, Trans, Boost, air press, coolant temp gauges, Cobra 29LX, 03 headlights, ccv w/ trap, 6.0 trans cooler, trans bypass filter, firestone & air lift bags, custom F650 dash, Rigid Ind LED lights, scangauge II,
I just bought new nerf bar myself, but they just lined up with the mounting brackets on my frame and all I had to do was bolt them in. Mine didn't have lights or anything so it took about 10 minutes. I don't know what bars you're interested in, but I got Lund 5 inch oval's and I'm happy with them. Running Boards | Truck Running Boards | SUV Running Boards
well i purchased the ionics 5" blow molded bars. they have aluminum rails underneath for mounting the brackets to the truck. so far very happy with them took all of 25 minutes to install. being plastic they shouldnt rust but the brackets are metal so will see how they hold up. very sturdy too as they hold my fat *** with no problems!
