Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-04-2012, 02:06 PM
nicks_57 nicks_57 is offline
Garage is empty, add now
nicks_57 is starting off with a positive reputation.
Crossmember Needed
I’m new to the forum, I recently bought a 57 F100 Styleside (short bed), 272 with a 3 speed and I need the rear engine/transmission cross member. The PO had planned to put in a 351 with a C6 and hacked off the rear engine/transmission cross member. This conversion seems pretty common so I’m hoping that somebody has this is sitting in their garage. Also, is this the same crossmember used in the 55-56 F100’s ?
  #2 (permalink)
Old 09-04-2012, 05:32 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Sorry, I hacked mine out too for my diesel and ch*** transmission gasp.. Welcome to the fridge club, where all the orphans hang out. Good to see a Seattle member. What area? See if you can get some photos up. Also we always need as much info as possible about your truck. We're not sure why, we just like these trucks and need the info. Thanks and good luck.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 09-04-2012, 06:57 PM
hotfalcoon's Avatar
hotfalcoon hotfalcoon is offline
1957 Ford F-100
My Garage
hotfalcoon is starting off with a positive reputation.
I can't remember if I removed mine yet or not but what pieces I did remove I drilled out the rivets, it is a 4 speed, not sure if 4 and 3 speed is the same. I'll take a look next time I get over there, not sure exactly where it might be.
  #4 (permalink)
Old 09-05-2012, 11:08 AM
norvillebob's Avatar
norvillebob norvillebob is offline
norvillebob is starting off with a positive reputation.
I have one here that I used a saws-all to cut out right at the frame rails. I tried to remove it by the rivets but no way was I getting it out. If your interested PM me your email I'll send pics so you can determine if will work for you. That's if hotfalcoon does not come though, I do not want to cut the line. Make me an offer, it's heavy.. The truck had a 3 speed Overdrive originally.
bob
__________________
Hi, my name is Bob.
  #5 (permalink)
Old 09-05-2012, 01:48 PM
deleted.....
  #6 (permalink)
Old 09-05-2012, 11:15 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Nick; I'm not sure if its the one you need, but I just seen it 1958 59 FORD TRUCK ENGINE/TRANNY MOUNT B8TZ 6038-A | eBay been on there a while now!
Good luck in your quest!
Disregard its the isolator not the cross member. Sorry its late and i'm tired.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #7 (permalink)
Old 09-06-2012, 11:34 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by theodore/teddy View Post
Another clueless ebay seller.
B8TZ-6038-A = .. Upper Front Insulator = 1958/60 F500/950 & 1961/72 C500/1000 401/477/534 V8's.
B7C-5026-A .. Rear Engine/Transmission Crossmember / Obsolete / ONE available NOS
Applications: 1957/60 F100/250 / 1959/60 F100/250 4WD.
OP: If you want this puppy, post your email address so I can give you the source. If I post it here, someone will snag it.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #8 (permalink)
Old 09-06-2012, 02:10 PM
thanks NumberDummy, it should be on the way tomorrow
  #9 (permalink)
Old 09-17-2012, 10:33 PM
will davis will davis is offline
will davis is starting off with a positive reputation.
Wink member needing crossmember for 57 f100 with 272 engine
i might have what you need. i have a 60 f100 with y block engine( i dont know what size) with 3 speed trans. what mine has is a big cast iron bell housing that bolts to the frame. get in touch.
  #10 (permalink)
Old 09-18-2012, 07:34 AM
Thank, I just got a crossmember last Friday and now the fun part of getting out the old rivets. Any easy suggestions?
  #11 (permalink)
Old 09-18-2012, 12:29 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Nothing easy about removing Ford rivets. Get the rivet head off one side, torch or grind, then heat the rivet red hot and drive it out with a punch
  #12 (permalink)
Old 09-18-2012, 01:50 PM
Thanks, I did grind off the heads and then tried to drive them out with a punch and big hammer but no luck. I ended up drilling 2 of the rivets out but 6 more to go. If heating the rivet is easier, I'll try that.
  #13 (permalink)
Old 09-18-2012, 05:55 PM
Quote:
Not just heat, cherry red so they are soft.
  #14 (permalink)
Old Yesterday, 10:08 AM
a4t1rat's Avatar
a4t1rat a4t1rat is offline
a4t1rat is starting off with a positive reputation.
Ok Bringing this back from the dead now I need one... HELP Let me know if you have one Thanks
__________________
Injection is Nice but I'de Rather be Blown
1957 F-100, 1958 F-100, 1960 f-100 4x4
1991 F-350 Dually / Blown 460
1941 Chevy Pro Street / Blown Big Block
2000 Excursion 7.3, 2008 F450 .. yes its modified
Freightliner Toterhome in the Process
  #15 (permalink)
Old Yesterday, 09:16 PM
to a4t1rat from willdavis1804@yahoo.com. I still have the truck and its all original so I should have what you need. I'm not good with emails and stuff so just give me a call at (205)915-4612. thanks, will
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
