New alternator problems
Old 09-04-2012, 10:00 AM
BuddyB's Avatar
BuddyB
BuddyB is offline
Help! Just installed a new 185amp DCPower alternator with new cables this past weekend. Before was reading 11.5-12.8 battery volts on the CTS with occasional battery light going down the road. Now, the CTS is reading 15.9 volts and I'm getting the overvoltage error code and all the dash gauges, radio, ac, power windows etc are not working.
Ideas?
Thanks
Old 09-04-2012, 10:05 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Have you cleaned all cables especialy the Grounds and where they mount to fram and engine
if that^^ dont help then might have bad voltage regulator
Old 09-04-2012, 10:18 AM
BuddyB's Avatar
BuddyB
BuddyB is offline
Grounds cleaned when I did the install. I've got the red cable going directly between alternator and battery (with in-line fuse). I went off other pictures with the new DCPower alternator installed.
Old 09-04-2012, 12:09 PM
bismic's Avatar
bismic
bismic is online now
Received 2,467 Likes on 1,709 Posts
Is the sensing wire connected?
Old 09-04-2012, 01:40 PM
BuddyB's Avatar
BuddyB
BuddyB is offline
Sensing wire? Don't really understand your question. The small connector (2 pin) is connected at the alternator and the new 0 guage waire from DCPower is connected at the alternator and battery. No pigtails off of that wire on either end.
Old 09-04-2012, 05:03 PM
berick's Avatar
berick
berick is offline
What did you do with the factory 4 gauge charge wire that comes from the OEM alternator?
Old 09-06-2012, 03:54 PM
BuddyB's Avatar
BuddyB
BuddyB is offline
Here's what I've done so far. Talked to the folks at DC. They said that the pigtail harness should be pushing 12.6 volts with Key On. That checked OK. I disconnected the 0 gauge wire from DC and re-hooked up the OEM wire from the Alternator and Battery. Drove home, 13.6-13.8 volts and no problems going home. Called DC on the way home and talked to I believe Owen about my problem. He stated that on the Powerstrokes he has found out that you have to hook up both the OEM and the new 0 gauge wire. Truck seems to be OK in the driveway pushing 13.6 at idle. Haven't driven the truck on the road last couple of days since it's nice so the motorcycle is the commute ride right now. Will try and take the truck into town for supper and a test run.
Old 09-06-2012, 04:04 PM
berick's Avatar
berick
berick is offline
News to me.... I just wrapped up the factory lead real good and ran the 1 gauge from the upgrade kit and I have not had any problems at all. Charge rate stays around 14.0 to 14.7 volts almost all of the time.
Old 09-06-2012, 06:13 PM
69cj's Avatar
69cj
69cj is offline
I would be concerned about boiling the batteries if the charge never went below 14 volts unless you have some heavy duty stereo equip. or something.
Old 09-06-2012, 06:17 PM
berick's Avatar
berick
berick is offline
It will drop to 13.8 if driving down the highway for any length of time. I do have a stereo system with an amp but I seldom have it turned up loud..... unless it's a sweet day! Most of the driving I do is maybe 30 to 45 minutes worth at a time.
Old 09-06-2012, 06:21 PM
69cj's Avatar
69cj
69cj is offline
I will vary from 12.8 up to 13.8 once in a while 14. Has done this since new and have never had a problem. Original alt. if your interested.
Old 09-06-2012, 06:28 PM
berick's Avatar
berick
berick is offline
Wow! Yours has done well if you are on your first alternator and it's still OEM (that's seven years!). I just replaced my second OEM with the DC unit awhile back. I had gone through an OEM 110 amp alternator under warranty and the last one seemed to always stay at 12.8 to 13.2 volts. As soon as I installed the DC it jumped up to 14.7 and of course came down after driving around for a bit. Happy with it so far.
Old 09-06-2012, 06:31 PM
69cj's Avatar
69cj
69cj is offline
Just make sure you keep an eye on your battery water. Too much voltage is just as bad as too little.
Osh
1999 to 2016 Super Duty
13
07-30-2019 10:45 PM
Knucklesmd
2004 - 2008 F150
11-14-2015 09:30 PM
Calheader
11-19-2014 02:30 PM
Jon351m
01-18-2013 05:49 PM
skyhawk1
1997 - 2003 F150
06-18-2006 06:16 PM
Quick Reply: New alternator problems
