1969 ford, restoration. - Ford Truck Enthusiasts Forums
Old 09-04-2012, 10:02 AM
Rodder69 Rodder69 is offline
Rodder69 is starting off with a positive reputation.
K guys, here goes. First ruck I bought with my own money, a 1969 ford F100 custom cab stepside. It had a 6 cylinder in it when I bought it and ran great. I enlisted in the airforce and had to leave it in a garage, 8 years later it comes out of the garage, 6 cylinder comes out and 302/351 goes in....not sure which motor it is yet I haven't measured to see for sure yet. I regret that, 6 cylinder ran perfectly the v8 does not , sold the 6 cyl, no going back.....Anyway rebuilt the carburetor (another thread) lost a bolt and had it flooding out EVERY hole, took it apart and found it to be the floats and needles.
NOW to the present. Yesterday I took it for a drive seems that I can't get its timing right it idles too fast, when I turn the throttle down it wants to die, also wants to die when it is in drive and the RPM's get to low....any ideas? I thought maybe the timing?
BUT when I got back there was antifreeze all over the bottom of the motor and frame . I can't win lol.
Turns out it was leaking around the water pump took ALL the pullys off and water pump off and sealed the water pump. BUT while removing the alternator bracket guess what........yep the bracket broke and they don't make it anymore (part number: d7ue-10a336-aa) found out they supposedly renamed that part, part number: e1az-10a336-a.
So I am now looking for that bracket so I can put the pullys back on to get BACK to adjusting the throttle and timing lol, cars are so much fun. Whoever had the v8 before me rigged up some bolts and spacers to make a aftermarket serpentine belt system work on the motor and it does for the most part so I am going next week to get all new bolts at the local hardware store that are correct in length and hopefully I will have the bracket found by then also and I can get back to trying to figure out why the truck dies at low RPMs. Updates next week when I get the parts.
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 12:09 PM
95 F-150 Saginaw p/s conversion: Bracket problem macintyremustang 1987 - 1996 F150 & Larger F-Series Trucks 17 05-13-2013 10:32 AM
Power steering bracket PRIMERED79 SHORT BED 1973 - 1979 F-100 & Larger F-Series Trucks 34 06-29-2012 09:38 AM
Ranger 92 Water Pump nhouston 3.0L V6 6 10-29-2008 02:36 PM
swaping 460 into 87 bronco.. ran into a snag... please read! vogey Engine Swaps 4 10-18-2004 03:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
