Fuel filter change question
I have a 2000 F350 SD with the 7.3 and have changed the fuel filter many times in the ten years I have owner her. Today I am changing the fuel filter, pulled the old one out, and opened the yellow valve in the back to drain the fuel out of the bowl and nothing happened. The fuel is just sitting there with me opening and closing the valve. I can see a couple little bubbles when I do that but the fuel does not run out. Is it possible to use heavy paper towels to clean out the old fuel and use an air nozzle on the hose end under the truck to blow what ever is in there blocking the tube out? Any suggestions would be great, Thanks, Danny
You've probably got something that's stopped up the drain line. My wife's did that. I took some electric fence wire and ran it up the drain hose from the bottom side to clear the obstruction.
Didn't really feel it, but I did it with the drain valve open and stopped poking around when fuel started coming out. I then left the drain open and turned the key on for a few seconds to blow the rest of the stuff out of the line.
The o-rings may be breaking down and it could be time to do a fuel bowl overhaul.
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
A lot of folks drain it down and wash the bowl out to wash everything out.
I have also done it that way as well.
That is just my opinion above but that is what I could see happening.
I was just going to suggest the bees. I had some busses coming from Ga. to Delaware. And they would stop around Whitesville, Va. could not get the fuel cap off with that much suction on the fuel tank. We used to carry a car antenna after that to push up the vent hose.
str400ex
10-23-2010 03:54 PM
vancouverpower
12-22-2004 01:51 AM
bodabdan
05-18-2004 05:26 PM
