You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
2012 edge 3.5
since there is such a long time between oil changes on these vehicles, is there any benefit to running a true synthetic like royal purple?
synthetic oils are made for peple that are putting 5000 miles a month on a vehicle and dont want to change the oil that often. If you are putting 1000 - 1500 a month, i think your still better off to change the oil every 5000 miles or 2-3 times per year. If you drive less than that, i would change the oil every year. The bad thing is to leave the oil in for LONG periods of time.
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
In my wife's 2008, I just use the Motorcraft synthetic blend 5W-20 oil and a quality filter every 5000. About 60% highway miles and with 80K on it now the oil still comes out just a light brown color. I am sure it could go longer, but every 5K is easy to remeber and keep track of. Plus doing oil change myself it is relatively low cost ($20 range).
Royal Purple is excellent oil. I think overkill for an Edge. If you really want to understand the oil change interval, you need to do used oil analysis and it will let you know when the oil is due for change.
__________________
1949 F-6 COE hot rod
1988 F-250 4x4 7.3 5-speed ATS
1937 Ford Utility Coupe (Ute) hot rod
Other old non-Ford trucks and cars
In my wife's 2008, I just use the Motorcraft synthetic blend 5W-20 oil and a Aftermarket Parts filter every 5000. About 60% highway miles and with 80K on it now the oil still comes out just a light brown color. I am sure it could go longer, but every 5K is easy to remeber and keep track of. Plus doing oil change myself it is relatively low cost ($20 range).
I wanna put synthetic in my 1994 ford focus, however I heard that switching to synthetic will break down old oil deposits is this true?
Why consider switching on a 20 year old car? Too much money in your wallet? Especially if you don't drive a lot of miles, use regular or syn blend oil and pocket the savings for a new car. Or take your wife/gf out to dinner.
If the engine has had regular oil changes, it should not have a lot of deposits. Synthetic does tend to be better at removing any deposits compared to dino oil. Just have a good filter and I think you will be fine, assuming the engine has had regular oil changes in past.
You might try a synthetic blend for a few oil changes before pure synthetic?
__________________
I always flip out when I see this question. If you change your oil every 5k miles it should be ok to switch. Then the other side says if it has build up no, it will screw your engine up. Which is crap science, if its dirty clean the engine out with a higher detergent oil, which all major brands syn use. this will clean the engine out. Just use a damn good filter and change it an extra few times tell the build up is gone.
If the engine has big *** chunks of sludge. No matter what the hell you do, the engine will fail if it blocks enough oil returns to start with. If you want to know if your engine is clean pull a valve cover and you will know.
__________________
I use Mobil 1 in all of my vehicles. On my MKT because of low mileage. My company is about six minutes from the house and most of my daily business is in that same range.
My company truck has 125,000 miles. Now it only drives about 5,000 miles a years so most of the time it backs out of the shop in the morning a pulls into the shop at night. So it gets the Mobil 1.
__________________
"A gun is like a parachute. If you need one, and don't have one, you'll probably never need one again."
Synthetic is made for engines that see more abuse than your average engine. That could be a granny doing 40 mph 3 miles a week, or Joe Stick shift doing WOT every time he gets in the car, and seeing closer to 200 than 100 mph.
This is why cars such as all 97+ Corvettes, all AMG, Porsche etc cars come with Mobil1 from the factory.
If you live in an area where the temp never goes below say 15 degrees F. you will probably see near 0 wear for 100,000 miles with high grades of synthetic motor oils changed properly with the best filters. Cheap plastic parts breaking is another story. They will probably still wear and break.
__________________ Women might not find ya handsome but they will find ya in your F150.
Ford Built_Ford Tough
There is no such thing as a 1994 Focus. The Focus was introduced in 1998 in Europe and in '00 in the US. So good luck with putting any kind of oil in your '94 Focus.
2 Edges, 07 and 10, 02 F150 5.4L and a '03 Southwind Motorhome with a V10 6.8L....all get 5W20 Ford Semi Syn every 7500mi and not a lick of issuses. Oil is clean going in and clean coming out. Just use a good filter.
