Stuck rotors anyone?
While doing my rear brakes, we struggled to get the rotors off. They were on there pretty good. Hammered and everything, no luck. So we improvised. It worked well.
How to Remove a Stuck Rotor - YouTube
Also, now that I have new rotors and pads in the rear, they squeak a LOT. Any way to fix this? They do it more when they are dusty (from trails, not brake dust) but seem to always squeak no matter what.
on
BRAKE SQUEAK
Brake squeak is usually caused by hard brake pads. Either get a spray can of commercially available anti-squeak compound, or coat the back of both inner & outer pads with some brake lube grease. Anything that absorbs vibration will quiet them down. The idea is to insulate the pads from the calipers--No metal to metal contact.
RON
Did you do the bed in procedure to "burnish" the pads?
I use disc brake quiet, new anti-rattle clips, springs and bed the pads in when I'm done. No squeaking.
My rear rotors were stuck fast. Hit around the hub to loosen the rust and smacked the outer rotor a couple times with a hammer. I was not using the old rotors so did not care if they got damaged.
Very cool method. Thanks for sharing that with us.
+1 on the pad bedding process. Here is a paper that discusses the bedding process and the science behind it.:
Brake Pad Bed-In
Brake Pad Bed-In
