dual aluminum rims?
dual aluminum rims?
Can we run dual aluminum rims on our trucks? I have a '94 F350 CC dually. I had bought a set of tires and Firestone damaged my rims. I made them buy me new rims, center caps and lugnuts. They were going to keep my rims until I not so politely told them to put my damaged rims in the bed of the truck and I drove away with new tires and rims and my damaged rims. The rims are only dented from the tire changing machines expanding fingers. The dents can be buffed out. They're more like deep scratches. Anyway would I have to get longer studs or longer lugnuts?
At minimum you need longer studs. But the reason most use the steel inner is because you do not really see it. Why pay money for something not seen? The width of the alum wheel flange will need longer studs for two. If your wheels are lug centric, then your idea will not work. Lug centric wheels have clearance around the lug holes and center using the tapered seat. The wheel put backward will not have the tapered seat. The inner wheel relies on hub centric mounting.
I have an 86 F350 with 16" duallys on it that are hub centric and the washer lugnuts.
I also have an 84 E350 RV with 16.5" lug centric rims on it.
I'd like to swap the truck rims to the RV and the local dealership said I could, just make sure the lugnuts go with the rims. BUT I was checking them out last night and the Truck rims have a small num inside the rim that keeps it from seating on the RV. I ground it off and it seats fine. I put the 16.5" on the truck and it will not seat all the way due to the center hole being too small on the rim.
Is the Dealership wrong in saying I can use the 16" hub centric rims on my RV? I don't see how the rims will be centered on the axle without either the lugnuts or hub making sure it is centered exactly.
Thanks Guys!
Thanks Guys!
I know this is a elderly post, but nevertheless.
You HAVE to run a steel inner rim!!!!!!!!!!
Because two aluminium flanges together, under pressure from the wheel studs/nuts and all the movement from the wheels itself, cause wear/fusing to the two flanges, thereby undooing the wheelnuts, running loose and coming off.
You imagine the situation you will find yourself in?
just don't run an aluminium inner rim on the rear axle, for your own sake.
Received 3,106 Likes
on
Thanks Guys!
Thanks Guys!
and most of the aftermarket 16.5 rims have the smaller chevy center hole. you had to specify the rims were going on a ford to get the larger center hole 16.5 rims.
