plow trucks
Old 09-02-2012, 10:42 PM
btracy's Avatar
btracy
btracy is offline
plow trucks
i have a 79 f150 w/plow and need to upgrade or get new front suspsion[coils].any pics and setup info helpful.
Old 09-09-2012, 05:45 AM
lostinfords's Avatar
lostinfords
lostinfords is offline
???? why?? I have a 79 f150 w/ a 7-1/2 plow w/ no problems and I had the same plow on my 78 bronco w/out any issues, in fact w/ the plow raised the f/e only dropped on both of the trucks...an upgrade may not be necessary but if you coils are wiped out just replace w/ oem, otherwise when you aren't using the plow it is going to ride worse than a skateboard
Old 09-10-2012, 02:40 PM
btracy's Avatar
btracy
btracy is offline
plow trucks
well id post attachment,but not allowed .
Old 09-10-2012, 05:44 PM
lostinfords
here are some pics of what I have/had
1...78 stock bronco w/ western plow, took it off, soon installing meyers and a 4" lift
2...78 f150 w/ 4" lift and meyers plow, soon getting cut up/scrapped and plow and lift going on 78 bronco
3...79 f250 sno fighter..parts truck..spare d60 and plow set up
4...79 f250 sno fighter..extra?? may use or not?
hope pics answer your ?'s
Old 09-10-2012, 08:19 PM
btracy's Avatar
btracy
btracy is offline
wow,maybe your right they all look like there sitting level,my nose is down.so with that i'm going to get hd 150 coils.thanks.you look like you have plenty of parts.
Old 09-10-2012, 09:03 PM
lostinfords
"plenty of parts"...you ain't seen nuthin"..but I am getting rid of the surplus so I can manage what I want to keep...remember if you lift the front too much then you are going to have to lift the back to 'level' it out...you may want to consider air bags to supplement the f/e when you have the plow on and then you won't mess w/ the suspension you have now...just a thought,...
Old 09-10-2012, 09:18 PM
btracy's Avatar
btracy
btracy is offline
well,i really think the front coils are shot.i do want to get f150 coils but just a hair stiffer or little bigger.i think lift kit springs are taller but not tougher.just made to lift for LOOKS.i want heavy duty springs.i know it will be stiffer.thanks.for info.if you have any springs let me know.
Bigazfordtruck
2017+ Super Duty
02-06-2020 07:07 PM
duphofff
12-21-2011 05:49 AM
Firefighter 1406
1999 to 2016 Super Duty
09-01-2010 09:34 AM
89fiveohman
12-23-2009 12:14 PM
Firefighter 1406
12-03-2009 07:12 PM
Quick Reply: plow trucks
