Can't figure out if I have a blown head gasket or not!
The problems started when I went 4-wheeling. I knocked a radiator line loose. It was repaired and I noticed my coolant was very brown. It was flushed and new stuff added. I changed the oil and filter. My mechanic told me I have an exhaust leak and that I had white smoke coming out of my exhaust. I saw the smoke myself but it doesnt happen all the time. Recently my coolant is brown again, I ran some coolant flush through the system and added pepper to plug a small hole. My engine hasn't lost any power. It runs normal, doesn't burn oil. At least not a really noticeable amout. And there is a misfire in cylinder 8. Any suggestions on what it could be??
try this link it should help you..good luck Part 1 -Head Gasket Test (4.6L, 5.4L). Blown Head Gasket.
There is a test kit to test coolant for exhaust.
That should tell you for sure if a cylinder is pushing combustion into the cooling system.
If you know #8 is missfireing, that's a good place to start confirming what cylinder it is.
When it's missfireing, remove the plug and look at the tip for moisture and compair to another cylinder's plug.
The white emmissions is the results of coolant passing through a hot cat.
It does not burn so is not black or grey because coolant is not a hydrocarbon like gas or oil.
There may be a sweet small to it as well.
Min is you will have to replace head gasket.
Good luck.
Good luck.
My buddies 04 (new model) 5.4L F150 had a small head gasket leak that was very hard to diagnose. The oil and coolant werent mixing because it was a small leak near the inside of the cylinder wall... thus letting coolant into the combustion chamber but no oil mixing with it. Oil check out fine, as did the coolant... but the biggest give away was misfire on cylinder #3 and the white smoke out the tail pipe that smelled sweet.
If your exhaust is white smoking pretty bad and smells sweet... my money would be on head gasket.
I have used the stuff before, has a slow leak that we couldn't find (eventually did find a rotted out block plug that was behind the PS bracket). It cost me both a radiator and a heater core.
Even in theory, the stuff might work on a small external leak, when the 15psi of cooling system pressure will drive the particles into the leak to form a seal. But against a head gasket you have the 150 psi of cylinder pressure versus the 15 psi cooling system. The combustion pressure will always force the particles out of the hole, clearing it, not sealing it. If the head gasket couldn't hold back the pressure, what makes anyone thing that some small particles will do better.
The older leak stop type stuff from 20 years ago that was aluminim flakes or oily pills was not the best sealer. THe new copper head gasket sealer is amazing. I cant say it works in every situation, and some people may have had additional problems that caused things to happen. I can tell you that i had a manifold gasket blow that caused a bad water leak and overheated similar to you. I changed out the manifold gasket and then noted a small leak , use of antifreeze. It was leaking into the combustion chamber and casuing rough running on startup and then used a cup full a week, etc.. I put the copper sealer in and that was 2 years ago and 40,000 miles and its fine. The new stuff does not attack the radiator or heater core. It plugs holes that have a big pressure drop across it, like a leak to atmosphere or combustion chamber. My cooling system works great, heater is fine, and air conditioner is fine... I was somewhat concerned as the guys mentioned above. I drained it after a year, ran the acid cleaner thru the system to see what would come out. After 2-3 flushes, i had the small gasket leak return. I added new antifreeze, a new bottle of copper sealer, and 15 minutes later, no problelm again.. that was a year ago. 40k miles total on 2 tests.
