Can't figure out if I have a blown head gasket or not! - Ford Truck Enthusiasts Forums
Old 09-02-2012, 08:27 PM
mrbeasly007 mrbeasly007 is offline
mrbeasly007 is starting off with a positive reputation.
The problems started when I went 4-wheeling. I knocked a radiator line loose. It was repaired and I noticed my coolant was very brown. It was flushed and new stuff added. I changed the oil and filter. My mechanic told me I have an exhaust leak and that I had white smoke coming out of my exhaust. I saw the smoke myself but it doesnt happen all the time. Recently my coolant is brown again, I ran some coolant flush through the system and added pepper to plug a small hole. My engine hasn't lost any power. It runs normal, doesn't burn oil. At least not a really noticeable amout. And there is a misfire in cylinder 8. Any suggestions on what it could be??
Old 09-02-2012, 08:29 PM
Sorry it's a 2000 f150 5.4l triton v8
Old 09-02-2012, 10:12 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
If your loosing coolant , i would buy a bottle of BARS copper head gasket sealer for $10 at AUto Zone and put it in the antifreeze and drive around the block a few times... Problem solved.
Old 09-02-2012, 10:26 PM
bigedusa bigedusa is offline
bigedusa is starting off with a positive reputation.
try this link it should help you..good luck Part 1 -Head Gasket Test (4.6L, 5.4L). Blown Head Gasket.
Old 09-02-2012, 10:46 PM
I know there isn't coolant in the oil, it isn't white. But the coolat down come out of the radiator cap
Old 09-03-2012, 12:07 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
There is a test kit to test coolant for exhaust.
That should tell you for sure if a cylinder is pushing combustion into the cooling system.
If you know #8 is missfireing, that's a good place to start confirming what cylinder it is.
When it's missfireing, remove the plug and look at the tip for moisture and compair to another cylinder's plug.
The white emmissions is the results of coolant passing through a hot cat.
It does not burn so is not black or grey because coolant is not a hydrocarbon like gas or oil.
There may be a sweet small to it as well.
Min is you will have to replace head gasket.
Good luck.
Old 09-03-2012, 12:38 PM
steve(ill)'s Avatar
IF you get coolant puke out the overflow tank cap after 5-10 minutes of running, thats a sign of compression in the antifreeze. Cracked head or head gasket leak... thats an easy fix for the Bars Copper sealer.
Old 09-03-2012, 06:34 PM
Would it be worth spending a few extra bucks for a gasket seal?
Old 09-04-2012, 07:44 PM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
Quote:
The "Applies to " section on the right of that link implies many more years of head gasket problems with the 5.4 L than I've heard. I thought they had that fixed by the end of the 2002 production year by making the gasket sealing surface boss larger?
Old 09-07-2012, 11:03 AM
Poolshark1321 Poolshark1321 is offline
Poolshark1321 is starting off with a positive reputation.
My buddies 04 (new model) 5.4L F150 had a small head gasket leak that was very hard to diagnose. The oil and coolant werent mixing because it was a small leak near the inside of the cylinder wall... thus letting coolant into the combustion chamber but no oil mixing with it. Oil check out fine, as did the coolant... but the biggest give away was misfire on cylinder #3 and the white smoke out the tail pipe that smelled sweet.
If your exhaust is white smoking pretty bad and smells sweet... my money would be on head gasket.
Old 09-07-2012, 11:10 AM
I'm going to try the bars copper sealer first and see if that solves the problem, otherwise new head gasket here I come
Old 09-07-2012, 03:36 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Quote:
That stuff is total crap. It should be called Bars Copper Engine Screwer. It works by putting small flecks of metal in the cooling system. These flecks will supposedly plug small leaks, which they do ok, but they also plug lots of other things. You can get similar results by adding an egg to your cooling system. Its not good for the cooling system in the least, its intended only to be used as a temporary fix until you can actually get the problem properly repaired. So there is no point in even trying it, your engine WILL need to be fixed, and it is cheaper to get it fixed right, than to add a bottle of junk to your cooling system and then have to fix both the original problem and the new problems the additive caused.
I have used the stuff before, has a slow leak that we couldn't find (eventually did find a rotted out block plug that was behind the PS bracket). It cost me both a radiator and a heater core.
Even in theory, the stuff might work on a small external leak, when the 15psi of cooling system pressure will drive the particles into the leak to form a seal. But against a head gasket you have the 150 psi of cylinder pressure versus the 15 psi cooling system. The combustion pressure will always force the particles out of the hole, clearing it, not sealing it. If the head gasket couldn't hold back the pressure, what makes anyone thing that some small particles will do better.
Old 09-07-2012, 03:55 PM
Wow ok, so should I spend $80 for all the gaskets or get it tested more before probably having to do this?
Old 09-07-2012, 08:55 PM
I'm getting a gauge to do a compression test this weekend, what should I look out for as a sign of a blown gasket??
Old 09-08-2012, 09:49 AM
steve(ill)'s Avatar
The older leak stop type stuff from 20 years ago that was aluminim flakes or oily pills was not the best sealer. THe new copper head gasket sealer is amazing. I cant say it works in every situation, and some people may have had additional problems that caused things to happen. I can tell you that i had a manifold gasket blow that caused a bad water leak and overheated similar to you. I changed out the manifold gasket and then noted a small leak , use of antifreeze. It was leaking into the combustion chamber and casuing rough running on startup and then used a cup full a week, etc.. I put the copper sealer in and that was 2 years ago and 40,000 miles and its fine. The new stuff does not attack the radiator or heater core. It plugs holes that have a big pressure drop across it, like a leak to atmosphere or combustion chamber. My cooling system works great, heater is fine, and air conditioner is fine... I was somewhat concerned as the guys mentioned above. I drained it after a year, ran the acid cleaner thru the system to see what would come out. After 2-3 flushes, i had the small gasket leak return. I added new antifreeze, a new bottle of copper sealer, and 15 minutes later, no problelm again.. that was a year ago. 40k miles total on 2 tests.
Disconnecting smog line from cat causing white smoke out tailpipe? NinthGenF-SeriesOBS 1987 - 1996 F150 & Larger F-Series Trucks 3 10-11-2016 05:13 PM
F-150 5.4L blown head gasket? matt1260 1997 - 2003 F150 6 09-28-2016 02:33 PM
Brown Coolant BlackNGoldRules Ranger & B-Series 18 02-24-2012 03:46 PM
some help with oil in coolant mellowfe 1987 - 1996 F150 & Larger F-Series Trucks 4 02-23-2011 05:56 AM
Oil in coolant? Troy77+79 Modular V8 (4.6L, 5.4L) 6 05-16-2010 10:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
